Question about Car Audio & Video
2002 chevy suv cd trying to eject cd no cd in
Son plays alot of burnt cd's and now after a cd was removed the player is still tryng to eject a cd even after the car is off and it ran the battery down. Do you know how to fix the problem. it will eject a cd automatically but then keeps tryng to eject with nothing in it.
  • Anonymous Mar 24, 2014
    reads "pause" or ejects, plays occassionally
    Sergeant:
  • 302 Answers
Disconnect your negative battery so it resets everything. But before you do that, does your radio have a security code? This won't let the radio play after disconnecting the battery. Its an antitheft deterrent. So I stress before doing that. make sure you have the security code
Posted on Dec 06, 2008
Help!! I have a library CD stuck in the CD changer. I can see it but it will not eject...it won't even acknowledge that it has a CD in the changer. I have tried tweezers, switching CD slots and trying to...
TRY TURNING OFF CD PLAYER.WAIT 10 MINUTES THEN TURN CD PLAYER BACK ON THEN PRESS THE EJECT BUTTON.SOME TIMES CDS PLAYERS GET HOT WHEN PLAYED FOR A LONG PERIOD OF TIME.MY CDS SEEMS GET STUCK WHEN I PLAY CD PLAYER LONG TIME.SOMETIMES IF CD DONT COME OUT .IF IT STICKING OUT JUST A LITTLE.TRY PUSHING BACK IN CD PLAYER THEN EJECT IT.THIS TRICK WORKS SOME TIMES.
Mar 11, 2011 | 2002 Ford Escape
My 2005 Chevy Malibu's 6 CD changer will not play CD's, and will not eject them either. When I press the eject button it appears to try and eject as I hear movement but after a short bit of clicks I get a...
Extreme heat can cause warping and the cd will not evenly eject or exit the slot. the player may have to be removed and the cd physically extracted from the player. Delco players have a lot of plastic cogs, flywheels and gears in them that get old and crack or split. Hence, the player can no longer spit out the CD.
Jul 26, 2017 | 2005 Chevrolet Malibu
Stuck CD in the multi CD player of 2004 Chevy Malibu Maxx
The only thing that is left for you to do is to remove the stereo and then disassemble it and remove it yourself. A little daunting but needs to be done. Sounds like it went in wrong and then became jammed
Jun 10, 2009 | 2004 Chevrolet Malibu
2005 chevy trailblazer cd player won't eject cd
I have a 06 Z71 and it did the same thing so more than likely your just going to have to buy a new cd player. I would recommend going with an aftermarket cd player because you probably going to spend just as much on another stock unit.
Jun 04, 2009 | 2005 Chevrolet Trailblazer Ext
2002 Suzuki XL7 CD player Err6 CD will not eject
Sounds like you may have been playing a copied or burnt CD, not an original. The radio/CD unit will have to be removed and taken to the audio dealer/agent for repairs.
Mar 01, 2009 | 2002 Suzuki XL-7
Factory cd player wont play burnt cds
A '96 CD player can't see newer burnt Cd's. Found that out with my '99 Chrysler.
Feb 26, 2009 | Phase Linear UDV9010 Car DVD Player
CD player won't work
Firstly is it burnt or factory cd? Most factory cd players won't play a burnt disk.
If you have a store-made cd and it is not reading that, then the lens inside the player is dirty and needs to be blown out with a can of "airduster"
Feb 01, 2009 | Audio Players & Recorders
2002 chevy trailblazer cd player
Are you trying to Play Burned CD's???? If Not, This IS a Common Problem on Chevy CD Players, My 95' Silverado went out and it was going to cost as Much for a New one as for an Aftermarket. Went Aftermarket. A LOT of people are having the Same Problems.
Jan 17, 2009 | 2002 Chevrolet TrailBlazer
My cd player won't eject cds
you might try and look inside the CD slot with a flashlight and if you can see a CD try to remove it with tweezers,you do have power to the player right? if no power it wont eject,
Jan 11, 2009 | 2002 Ford Excursion
Have a Blaupunkt AM FM Radio/In-Dash Ch Cgnager (6 stacker) in a 2003 Holden Commodore. After ejecting the 6th one of the CD's succesfully, get "CD Error mech" message and it will not eject the...
We eventually tried loading another CD to fill the one vacant spot we knew was in the changer even though we'd tried that before without success. This time it seems that we fluked it just as it was trying to eject CD 1 again and - somehow - the CD we were tryng to insert must have lifted the rim of the one that was stuck and it suddenly ejected. The remaining 4 CD's that were inside the changer but not even recognised, then started re-loading so it appears that they were all jammed up together. Once they'd reloaded we were able to eject them all successfully then reload.
We're not sure but think that it may have happened when the eject button was originally pressed once to eject CD 6 then, in error, held down for a 'eject all' procedure and the changer has become confused with both instructions.
Jun 01, 2008 | Blaupunkt Car Audio & Video
Car Audio & Video Logo
147 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
