Cant go online with my dell insperation 1000 it says low or no connectivity was wondering if there was a way to do a system restore to solve the problem ..getting real frustrated
    Novelist:
    Scholar:
  • 85 Answers
Sure you can try system restore and restore it to the day before the problem occurred but if it has been a while then it is possible that there may not be a restore point available to restore it to
And if that is the case then open "network connections" in the control panel and "right click" your connection that says limited or no connectivity and select "status" from the drop down menu then click the "support" tab on top and where it says "IP Address" look to see if it starts with a 169.xxx.xxx.xxx number and if it does start with 169 then that means that your computer was unable to acquire an IP address from your router or modem and it assigned itself a default machine address of 169.xxx.xxx.xxx (xxx is just space filler for numbers they could be different numbers) And so if it does say 169 then click the repair button and it will try to acquire a new address and if it is still unable to acquire an address and you end up with a 169 number again then if you have a router go over to the router and unplug the power cord for 10 seconds and plug it back in and then click repair again and it should work.
Most routers assign an IP address that starts with a 192.168
if you don’t have a router and your modem is plugged directly into your computer then try unplugging the modem and plugging it back in but wait for the modem to initialize (boot-up) all the way (you will know when all of the lights on the modem are on) before clicking repair button.
if none of the above helps then let me know and ill take you to the next step in fixing the problem
Posted on Dec 06, 2008
How do i restore to factory settings my Dell Vostro 1000
Try here...(http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_336966&isLegacy=true#Issue3).........or here........(http://www.techsupportforum.com/forums/f108/solved-dell-vostro-1000-restore-from-recovery-partition-issue-445057.html)
Nov 20, 2011 | Dell Vostro 1000 Laptop
How solve optiplex GX400LOW SPEED
To solve low speed you need to restore your system to that level when your system speed was not low or repair your corrupt registry files.
you can use RegInOut to repair your registry files and sppedup your system.
Hope these tips works for you.
Sep 06, 2011 | Dell Dimension 2400 PC Desktop
I updated the bios on the dell vostro 1000 and it wouldn't start. The power light stays on and you can hear the fan. This is followed by a long beep and 2 short beeps while the screen stays black.
Hi alkeith...
Turn on the computer while tapping F8, this will take you into the Safe Mode.
While your in the Safe Mode you can do a system restore.
Restore your computer back to an earlier time when it was working before you installed the bios change.
Left click on Start>All Programs>Accessories>System Tools>System Restore.
This should solve your problem.
Please take time to rate me
Aug 05, 2011 | Dell Vostro 1000 Laptop Computer (AMD...
Infinit loo between online and on battery?
With all 5 units behaving the same, I would expect that the power is still out of range. If the power is too high or too low (see manual for thresholds) the unit will stay on battery power to protect the attached equipment. If you have the software loaded, it will show you what the input AC voltage is at. Otherwise, it could be time for new batteries: http://batteryinternational.com/apc-smartups-1000-ups-battery-ups-batteries-f2.html
May 09, 2010 | APC Smart-UPS 1000VA UPS System
I just reformat my dell inspiron 1000, I wasnt able to install any ms-office to it I cant connect to the internet without restarting its services? when I restart my laptop almost all the services stopped?...
Ok go to Start>>Run>>services.msc when it opens, choose the services you want to use and click "Start" and set to Automatic Startup where necessary.
Feb 09, 2010 | Dell Inspiron 1000 Notebook
How do you format the hard drive on Dell Inspiron 1000. I have the restore system disk and don't have anything on it worried about losing...just need to format and start fresh..it's got too many issues and...
I'd put ubuntu on it, if it's a inspiron 1000, should run ok. If you have the restore disks from dell, just turn it on, pop in the cd, then reboot, the pc should boot from cd, then just follow the promps, make sure you delete all partitions, format thorough (not quick NTFS), use the whole disk for windows
Apr 06, 2009 | Dell Inspiron 1000 Notebook
Looking how to do a system restore
The easy way would be using the 'system restore" included in MS Windows.
-Click the Start button, point to All Programs→ Accessories→ System Tools, and then click System Restore.
-Ensure that Restore my computer to an earlier time is selected and click Next.
-Click a calendar date to which you want to restore your computer (when everything worked fine)
-Click Next.
The Restoration Complete screen appears after System Restore finishes collecting data and then the computer restarts.
6 After the computer restarts, click OK.
Dec 06, 2008 | Computers & Internet
My dell inspiron 1000
Can you see the Dell splash screen after turning it on at least? Check first your hard drive by doing diagnostics. Hit F12 for the diagnostics options to test its functionality. If everything passes, then there is still a way to recover the files. Are there any files on your computer that needs to be backed up? You need to consider this before doing the restoration options.
Sep 26, 2008 | Dell Inspiron 1000 Notebook
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
