Question about Crimestopper EZ-95FM EzeeStart 2-Way FM/FM Remote Start System w/5-Button R
Remote got wet
Accidentally dropped remote into sink full of water, took everything apart so that i can have em try. put everything back together in order and the indicator light is working when ever you press the start button but the system is not responding at all. what do i do. please help.
  • 95 Answers
You can try reprogramming the remote to the remote start but if that doesnt work you will need to purchase a new one.
Posted on Feb 19, 2009
Hoover nano cyclonic shut off while in use/no suction when turned back on
That is more than likely the problem, NEVER put wet or even damp filters back into your vac
Oct 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
Its not working for me plz help. Bush 40inch smart tv remote is not working
Did you ever get the remote control wet? If so it can be taken apart and cleaned of any sugary contamination with water, a drop of soap and a toothbrush... dry and then put back together. If it is imperfect crazy glue foil to the bad buttons
Oct 21, 2013 | Televison & Video
LG VU GOT WeT!!!!!!
Ok. Heres what happened to me:
I forget my LG Vu (CU920) was in my pocket and I jumped in the pool. I was in the pool for about 10 minutes before I realized. It was full of water. I took the battery out as soon as I realized it. HERES HOW I FIXED IT!!!!!!!!!
Step 1- I took it home, removed the screws on the back panel, and removed it. Now the entire back casing was off.
Step 2- I put the phone and battery (separate) in a bowl of uncooked rice. Sounds crazy but this absorbs all of the water. I left it in there for 2 days.
Step 3- After 2 days, I put the battery back in and everything turned on. Only problem was there was a big bubble in my LCD screen. I then took the phone apart further by popping of the front casing of the phone. I then try to get underneath the LCD to air it out, but I accidentally broke the LCD screen (inside the phone...not plastic outer screen).
Step 4- I went online and purchased a new LCD screen for around $40 from a cel phone parts website. I got it and installed it which was not too hard. You just have to remove all the visible screws (i believe there are 6) from the back side. Then pop off the front cover and the rest is pretty obvious.
Step 5- Put it all back together and it all worked again!
Step 6- My battery soon died after of all this...Im guessing from the water damage. I bought a new one online for around 20 bucks. Now the phone is good as new.
All in all spent 60 bucks and revived the Vu from water damage!!!!!!!!!
Jun 28, 2009 | LG Vu CU920 Cellular Phone
Water
Sometimes when electronics are dropped in water, you can still use the. Circut boards have a silicon coat over the circut boards for instances like this. Depending on how long it was in the water, you may be able to still use it. Let the phone dry out for about 24 hrs (take out battery and back cover) then try to replace the battery and start it back up. If it doesnt turn on the circuts were affected and it broken.
Jun 24, 2009 | LG Vu CU920 Cellular Phone
Dropped my HP 12C into the sink (full of clean water)
Yes, take it apart, and wash the circuit board.
Hard part is taking it apart without breaking the little tabs that snap the case together. It may have a couple hidden screws somewhere like in the batt compartment or under a label or under the rubber feet. Then carefully pry the case joint apart to get the snaps to let loose. Then the circuit board easily comes out - be careful if all the keys are loose not to disturb them. Also be careful of the display that may be loosely mounted. Once you get the board out, you can wash it with soap and water - whatever, just rinse it when clean with something like alcohol so no residues are left. Also be careful to not rub off any off the black key contact spots where the keys touch it. Put it back together loosely and see if it works.
Hope Ya Fixit !!
Fame !
Jun 17, 2009 | HP 12c Calculator
Dropped my cell in water
does your phone still work after being submerged?? i did the same and it was toast...
the screen is layered...glasss, lcd, and they are not meant to come apart. The phone needs to be left out, taken apart as far as you can get to air out. Leave it for a day or so, and put together. Hope this helps
May 05, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Everything works but the touch screen.
caring for the touch screen includes touching the screen with clean and DRY hands., if your phone fell in the water, it will likely damage the touch screen.. contact your nearest LG repair center.. i hope your phone will soon be fine..
May 01, 2009 | LG Vu Cellular Phone
Sidekick 2008 got wet
I dropped a phone in the toilet once, a T-mobile phone. it took a couple of days for it to dry out completely. Then I snapped it back together, and it was fine. Being that yours just got wet, and not immersed is different though, so you may want to take it into T-mobile and see if they can check it out for you because then you will know for sure what is going on. Good luck.
Jan 12, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My phone got wet help
I took the phone apart and used an electrical contact cleaner on the phone and sprayed the hell out of it minus the battery which you will have to buy a new one. The put a fan on it for a day then let it sit on the dashboard of my car for a day. Put it all back together and it works Mine was dropped in 18 feet of salt water
Oct 30, 2008 | LG VX-8700 Cellular Phone
Crimestopper EZ-95FM EzeeStart 2-Way FM/FM Remote Start System w/5-Button R Logo
270 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Frank Mangiapane
Level 1 Expert
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
