Question about Refrigerators
MY HOOVER HNMF 2805A L80 the fridge compartment is freezing everything, the freezer part works fine, is it the fridge sensor that is faulty, how do I get to it Hoover A class bottom freezer refrigirator (lost manual not sure of code until I pull it out from wall) - The fridge compartment is freezing everything, it is freezing harder on bottom shelf than top, any tips?
  • 1 more comment
  • oggy2 Dec 06, 2008
    Hi dej411,
    I have lowered things in freezer compartments but I don not think anything was blocking the blowers, it has been fuller in the past.
    There is only one temp control (0 to 5 and at 5 "Super freeze" switches on) I have turned this down to 1 (normally set ~2.5) for last couple of days but no change. I turned the control to 0 but this was only about 5 hours ago (so no difference observed yet).
    Inside the fridge there is only one small hole for water run off, the rest of frige lining is smooth, so there would appear to be no forced air circulation within fridge comparment. Thanks in advance for your advise.
  • Anonymous Mar 21, 2014
    I am not sure why this is happening. I thought it may be from the rubber seal around the freezer door being pulled out at certain points, but I took the screws out and pushed it back in place, then tightened the screws again. This didn't help. The fridge is still thawing and then freezing and thawing and...ect. This viscous cycle did effectively ruin all my meat. I am studding auto electric and I have tools. Can I fix this myself?
  • Anonymous Mar 24, 2014
    top shelf of fridge freezes
  • 88 Answers
Try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Posted on Dec 06, 2008
My Hoover 400 cyclic refrigerator motor won't stop running.
what setting do you have the control knob set to ?
Feb 12, 2015 | Hoover Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
I had same problem. Needed a new thermostat. Lasted about 18 months, then needed to replace fridge. Ice build up is between the inside and outside layers of the fridge as well. May just be more economical to replace. Cheers
Oct 26, 2010 | Hoover HCA331FFK
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
Fridge compartment is freezing food/milk etc
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 06, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Frostfree hoover fridgefreezer
If its freezing at the back that indicates refrigeration is good. it sounds like you have a thermostat control problem. Replace the thermostat.
Jan 12, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge compartment is freezing in my Hoover upright fridge-freezer. Any advice greatfully recieved. Thanks, Owen
have you tried turning down the temperature for the freezer or fridge? The fridge gets its cold power from the freezer, it is siphoned into it. So turning down the freezer temp may help but a sensor may have gone bad in the motherboard of your freezer and not closing off the vent into your fridge
Dec 06, 2008 | Hoover HCA390FFK Bottom Freezer...
i had the same problem the sensor starts at the back of the pcb and snakes its way dow the back of the fridge into the freezer conpartment i ordered a new sensor thinking it was a temp sensor but turned out to be a defrost sensor compleat and utter hassel to fit due to the expanding foam i had to eventualy cut the block off that conects to the pcb and then reconecting it once i got the cable through the foam first 2 days seamed to work fine while there was nothing in it as soon as i put food in it again the fridge started to freeze everything again then about a week later it still ices up at the back the fridge but doesnt seam to freeze the food so much now so still unsure about it all
btw it was the exact same model and before i changed the sensor the light and the super light used to flash on and off
Dec 02, 2008 | Hoover HCA390FFK Bottom Freezer...
Refrigerators Logo
1,214 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
