Question about Samsung Cell Phones
My new Samsung JetSet SCHR 550C will suddenly emit a high frequency squeal during calls and lock up. I have to pull the battery to make the phone usable again. I have received the flash firmware upgrade but that did not help. I know of two other people that have the very same problem. A store rep tells me this is a known issue. But there is no other info forthcoming..?
I have the same problem but here's a temporary solution until they come out with a software fix...press the number 3 when the phone begins to screech...and your call will continue. Keep watching for another fix it'll be here soon!
Posted on Dec 06, 2008
Tip
Brake Squeals
Most brake squeals are cause by a high frequency vibration. To eliminate this condition the pads need to be secured properly to their mounting and new hardware (if applicable) should be replaced during installation.
on Jul 27, 2010 | Acura Integra Cars & Trucks
How to download music to samsung schr 451c
When your file starts to download a browse option should open you can select your samsung schr drive or once its downloaded you could copy and paste the file into or drag and drop it into the samsung schr drive
Mar 18, 2013 | PNY 2GB microSD Memory Card
2004 trailblazer ext high beam headlights wont turn off and the relay makes high pitched noise
Need to check the ground path on the squealing relay. A poor ground will cause this condition.
Feb 27, 2013 | 2004 Chevrolet Chevrolet TrailBlazer EXT
High frequency noise from toshiba dvd recorder
if you can remove the cover of your dvd recorder, then access the power supply board first check if their is bulging capacitor or transformer which emits the noise.if ok, observe if the noise is coming from the dvd burner during recording.
Sep 15, 2012 | Toshiba DR410 DVD Recorder
Hello Sir !!! i have S.E K750 , During call voice is disturbing because of NOISE (like KkkkkHHHhRRrrrRRrr KHoRRrrRRrrr).. and the listener also dont hear my voice clearly ...(Sorry for my bad English) i...
had you slip your phone on the floor?get it wet?always near on high frequency appliances?therwes so many possibilities that can occur to that phone...if it fall,maybe the mouth piece has a defect and its hardware problem.,..please stay away on high frequency app. when ur making a call..go to the nearest SE center for check up..
May 12, 2011 | Sony Ericsson Cell Phones
TV is emitting a high pitch squeal, even does it when muted. It's becoming more frequent.
IF the TV is still playing, you have a vibrating part on the main circuit board close to the or in the horzontal/high voltage section. Like a loose
coil in its housing. If the TV won't come on, then you have something shorted causing the power supply to go into a reduced output mode.
The power supply is overloaded due to a short which is probably in the horizontal circuit. Power supplies oscillate at a high frequency which you normally can't hear. Like 40khz.
Jan 04, 2010 | RCA MM36110 36" TV
How do i only lock my text messages on my jetset phone
it will be in ur security option...further application lock
Oct 23, 2009 | Samsung U900 Soul Cellular Phone
Samsung JetSet absolutely frozen.
Go to your nearest Samsung JetSet service center, and
have it checked.
Sep 24, 2009 | Samsung U900 Soul Cellular Phone
Samsung 42' Rear projection - High freq squeal
solder around pins on flyback transformer,see if this will solve your problem.some flybacks will make this sound, like a ringing noise.
Jan 19, 2008 | Samsung HC-P4241W 42" Rear Projection...
Cell Phones Logo
65 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
