Question about Kenmore Elite 45986 Front Load Washer
My Admiral Washing machine only runs the hot water (not cold)
I have ensured the cold tap is working... But when I start the washing machine it only uses the hot water. I cannot find a setting on the machine to select hot or cold. I have tried turning off the hot water tap and leaving the cold on. If I do this, then no water comes out at all. i have exactly the same problem and it annoys me that I now have to call someone to fix it since the machine is only three years old. another Sears disaster!
  • 302 Answers
If you want to use cold water, switch your hoses from hot to cold and cold to hot. You will get cold water now
Posted on Dec 06, 2008
WI815 Intuitive Eco - no cold water
IW Intuitive Eco.
Water valves have a rubber diaphragm that wares out
after some time,
So yes you are right water valves need replacing.
Apr 21, 2014 | Fisher and Paykel Washing Machines
Fault-F13 What does it means?
Hotpoint Washing Machines and Washer Dryers
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred. Book a washing machine repair
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a washing machine repair
  • F17 - Door not closed properly. Close door firmly at the 3 o'clock position.
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing. Book a washing machine repair.
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book a service engineer.
  • F40 - Water below protection level during a heat step. Book a washing machine repair.
  • F41 - Water level detect sequence incorrect. Book a washing machine repair.
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language). Book a washing machine repair to re-programme your product.
The code f-13 refers to the water valve. Check it for any obstructuions in the screen and if your thinking it is bad you can always swap the hot and cold lines and change the settings to get the temperature you want and that will tell you if one of the valves is not working. Say if you want cold but no cold is coming into the waher, swap the cold and hot lines and call for hot water, if cold comes in then, then you will know that the cold valve is bad. If neither valve is working then replace the assembly
Sep 15, 2011 | Hotpoint Washing Machines
Washer will not fill with cold water only hot
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Apr 19, 2011 | Admiral Washing Machines
When i try and start the washer it hums it won't fill it spins just won't fill
Hi and welcome to FixYa, I am Kelly
Turn off the water at the wall connection remove the hoses noting the positons of HOT and COLD. Then clean the inlet screens in the water valve. (lift out by using a knife blade on the outside of the screen) Wash the screens by rubbing your fingers ofer them under slow running water then reinstall them.
Before you start try a hot wash.. and then cold wash to see if either has water coming into the machine. If it works there is a way to back flush the water valve using a warm water wash. You remove one hose and stick it in a bucket. Turn ON the other hose and let water flow into the bucket while gentily tapping on the hose connection with a screw driver HANDLE. Reverse hose connections and repeat hose in bucket and tapping on hose connection. Reconnect both hoses then try HOT and COLD wash fill cycles. Let me know what happened.
Thanks for choosing FixYa,
Dec 13, 2010 | Admiral Washing Machines
GW52F Fisher and Paykel Washing Machine Col...GW52F Fisher and Paykel Washing Machine Cold water valve does not seem to be letting any water into the washing machine, so it does not spray rinse or deep...
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
Jan 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Why is my warm water is cold? The hot is hot and cold is cold but warm is cold.
There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
Jun 28, 2009 | Admiral AW22 Top Load Washer
the water temp switch is bad call aplience parts store in the area
Nov 25, 2008 | Admiral AW22 Top Load Washer
Admiral washer wont take in cold water
I to have the same problem except it is my hot water that dribbles
Dec 15, 2007 | Admiral AW22 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
255 people viewed this question
Sal De
 Brian Main
Brian Main
