I figured out your problem because i was experiencing the same thing. The memory card has a tiny white switch on the side of it that says "lock". I'm guessing you accidently moved it like i did. I hope i helped you :)
I just fixed this problem on an S730, the lens was out but partially stuck on one side which was causing the camera to shut down.
you should be able to free it.
Same problem... beeping, lense won't advance out when turning on & won't retract when turning off... Randomly turns off! Not a great camera!
same exact problem. Piece of ****.
same problem (the lock button dont work) so its something els
I have the same exact problem, and tried the memory card, still didn't work...
same thing
Mine is doing the same thing...3 beeps then it won't turn on or do anything, i tried the memory card even just taking it out it won't turn on.
I also have the same problem..when the camera is turned on it beeps 3 times..little green light..the camera status lamp lights up and then the camera shuts off..have tried new battery's..switch on the side of the memory card..and even no card. still wont stay on..just shuts off after the beeping stops.
my problem is the same..camera beeps three times then shuts its self off..tried the switch on the memory card..new batteries..even no memory card..still shuts off.
i have the same problem... i cant take out the lens.
