Question about Krups FDH212 10-Cup Rice Cooker
Slow Cooker Won't STAY on "Slow Cook". Switches to "SLOW COOK"
Aghhh! I'm so frustrated.
I just put all of my ingredients in my Krups slow cooker to make my beef stew, but when I set the "slow cook" option, and then set the time for 7 hours, then press "start"....it is fine for about 3 minutes, then it switches automatically to "Keep warm"!! I know this is a feature of this cooker, but it's only supposed to switch to keep warm when it's DONE cooking the ingredients! I know my meat and veggies are NOT cooked in three minutes!! Anyone know what's up??
Thanks!
  • weezyhj Jan 19, 2009
    I hate to say it, but this happened to ours . . . and then it stopped working altogether. Apparently there are many of us with the same problem here--I hope that someone finds a solution!
4 Suggested Answers
SOURCE: rice cooker
http://www.kitchenmanuals.com/manuals/mfg/krups/krups_rice_cooker_product_list.html
Posted on May 17, 2008
SOURCE: Krups FDH212 10-Cup Rice Cooker Problem
Anybody have a solutions for this? I have the same problem.
Posted on Sep 08, 2008
  • 3 Answers
SOURCE: Couldn't find the manual for the krupps 230 70 egg
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={D322C1B5-1C64-4511-98EC-E9156C79F347}&SelectedProdRef=230
Posted on Sep 10, 2010
How is it used as a slow cooker
It is already a slow cooker. You just add your ingredients and plug it in and wait patiently, because it takes a longtime to cook in a slow cooker. I have one.Usually 10-12 hours.
Jun 08, 2017 | Crock Pots & Slow Cookers
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
HOW TO COOK CAKES IN SUNBEAM SLOW COOKER
Ingredients
Original recipe makes 1 cake
  • 2 cups white sugar
  • 1 3/4 cups all-purpose flour
  • 3/4 cup unsweetened cocoa powder
  • 1 1/2 teaspoons baking soda
  • 1 1/2 teaspoons baking powder
  • 1 teaspoon salt
  • 2 eggs
  • 1 cup milk
  • 1/2 cup vegetable oil
  • 2 teaspoons vanilla extract
  • 1 cup boiling water
  • PREP20 mins
  • COOK3 hrs
  • READY IN3 hrs 50 mins
Directions
  1. Spray crock of a large slow cooker with cooking spray.
  2. In a medium bowl, whisk the sugar, flour, cocoa, baking soda, baking powder and salt. In a separate small bowl, whisk together the eggs, milk, oil and vanilla until well combined. Whisk in the boiling water. Pour the wet ingredients into the dry and mix well.
  3. Pour the cake batter into the prepared slow cooker.
  4. Set slow cooker to "Low". Cook until cake has no wet spots on top and has pulled away from the sides of the crock, about 3 hours. Turn off slow cooker and allow cake to rest for 30 minutes before serving.
Sep 08, 2014 | Crock Pots & Slow Cookers
How to cook in the slow cooker
Most slow cooker recipes are very straightforward. You put the ingredients in, and select your cooking time. Most slow cookers have slow (8+ hrs) and fast (4-6 hrs) options. Here is a site with a wide range of recipes. http://allrecipes.com/recipes/main-dish/slow-cooker/
Oct 14, 2012 | Bravetti MC665H 7.61-Cup Rice Cooker
Slow Cooker Beeps only after a few minutes and won't stop.
4 years later... I'm pretty sure it has to do with liquid in the slow cooker (maybe relating to temperature also so it doesn't overheat/burn your meal?). I just threw in some short ribs and a thick (and somewhat scant for the cooker's capacity) bbq sauce. It started beeping and beeping and beeping at fairly frequent intervals. I added about a cup of hot water and the beeping stopped.
Jun 30, 2012 | Kitchen Appliances - Others
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
Ronson slow cooker settings
Hi. I'm a Ronson Service Centre in Australia.
I grabbled this blurb from a Ronson Slow Cooker Manual.
On Setting 1 (Low) the Slow Cooker can operate all day and night if required.
When set to 2 (High) it is very much like a covered pot on the stove. Foods will cook in ½ the time required for 1 (Low)
When set to Auto, the Slow Cooker will cook on 2 until the food reaches a pre-set temperature, then switches to 1 and maintains a constant slow cooking temperature.
“Auto” is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
Nov 24, 2009 | Crock Pots & Slow Cookers
Can't change temperature-stays on "warm"
Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
May 19, 2009 | CorningWare SC60 Slow Cooker
When I turn it on I get E01
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be rese
Dec 19, 2007 | West Bend 84496 6-Quart Slow Cooker
Krups FDH212 10-Cup Rice Cooker Logo
83 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Henry  Thomas
Henry Thomas
Mike
ArcFlash
Level 1 Expert
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
