Question about HP PSC 1600 InkJet Printer
Psc 1600 all-in-one series
Unit won't scan or copy. it appears that the scan bulb is not lit to full power. can not find parts.
  • marty maltz Feb 18, 2007
    does anyone know where I can get parts? Cost to repair is more than the unit it worth. Is it worth fixing or buying a new one.
  • Nyte Apr 20, 2008
    My PSC 1600 WILL NOT COPY OR SCAN, ALL OTHER FUNCTIONS WORKING APPRECIATIVELY(PRINTS FROM COMPUTER). THE SCAN LAMP APPEARS TO BE WORKING OR ILLUMINATED.
    Master:
  • 638 Answers
Get a new one is much advisable.as the cost is near to $80
Posted on Nov 08, 2008
My printer window on the HP PSC 2175 continues to read: 'Press Enter to align cartridges' I have done this 5 or 6 times and the message will not go away. How do I fix this problem so it will print?
Perform the following steps to align the ink cartridges:
  1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
  2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
    1. Press Setup or Menu on the front panel (depending on the model).
    2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
    3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
  3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
  4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
    • If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
    • If the message keeps reappearing or other print quality problems occur, service the product.
Models with a semi-automatic print cartridge alignment Some HP products have a semi-automatic alignment process. These models do not have an additional sensor and will print two pages for the alignment process instead of one. The alignment page must be placed on the scanner glass or into the automatic document feeder (HP Officejet V series) and scanned.
  1. Disconnect the power cord, wait five seconds, and then plug it in. This reinitializes the product and forces the scanner to calibrate again.
  2. Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the product must be serviced.
  4. Verify that the alignment page is placed correctly on the scanner glass or in the ADF (if the product has one). Place the printed side down.
  5. 5. Make a copy of the alignment page. The unit will make a copy even if the alignment message is displayed. Compare the copy to the original. If vertical lines appear in the copy, check to see if the scanner assembly requires cleaning. If cleaning the scanner assembly does not correct the problem, service the product.
  6. 6. Use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. Operate the HP All-in-One to determine if there are other problems. The unit should be serviced if other error messages or problems occur or if alignment problems occur every time the ink cartridges are changed.
To bypass the ink cartridge alignment: Press and hold the Setup button, and then press Options (or Copy Options ).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 26, 2011 | HP PSC 2175 All-In-One InkJet Printer
Colored lines on a copy page
To fix the colored lines on a copy page do the below steps
  1. Disconnect the power cord, wait five seconds, and then plug it back in. This will reinitialize the unit and force the scanner to calibrate again.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the unit must be serviced.
  4. Verify that the alignment page is placed on the scanner glass or in the automatic document feeder (if equipped) correctly. Place the printed side down.
Dec 10, 2010 | HP OfficeJet k60 All-In-One InkJet Printer
When I try to copy or scan from the glass it tries to feed from the automatic feeder tray instead.
Make sure there's no paper in the tray.Use the printer control panel to scan.
First Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English)
Second Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English) or reversal.
If this not work reinstall the printer.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 17, 2010 | HP PSC 1600 InkJet Printer
HP psc 1410 all scans and copies are a total black
Yes, either the lamp or photo sensors in the scan assembly. You need a torx driver to remove the top and back covers and check that all ribbon cables are plugged in fully, sometimes a poor connection can cause that problem.
Apr 20, 2010 | HP PSC 1410 All-In-One InkJet Printer
I have a NEC mt1055 and the unit just had new bulb put in here and it has the power and standby light come on and the fan doesn't turn on here and the standby light is yellow and status is red
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
  • Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
  • Using the remote control, hold down the power off button for 30-45 seconds
  • This will reset the status button, removing the red light
  • Power up the projector and select Menu
  • Select Projector Options
  • Select Set-up – a number of tabs will appear called pages
  • Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
  • Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
  • Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
Oct 07, 2009 | NEC MT850, MT1050, MT1055, MT1056...
My hp psc 750 the dont scan but the printer work
hi
Clean the upper part of the scanner glass with soft cotton cloth. Ensure their are no visible marks on the glass.
If the printer power cable is connected to the surge protector, connect it directly to the wall jack and then perform power cycle on it.
Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
After performing power cycle, you need to perform semi-full reset.
Press and hold Cancel and the Left Arrow key on the front panel keypad, while plugging in the power cord.
Put the printer as stand alone and try copying any normal document by placing it on the scanner glass.
Issue persists check if the scanner bulb is glowing and also able to move. If the scanner bulb is either not moving or glowing, the problem is related with hardware and needs to be serviced.
cheers
Jul 26, 2009 | HP PSC 750 All-In-One InkJet Printer
I can't scan anything on this machine
As long as you have downloaded the software that came with printer and installed the printer with an usb cable, it should be really easy such as just hitting the scan button and it will pull up the pic after scanning.
Feb 09, 2009 | HP PSC 2175 All-In-One InkJet Printer
I want to scan
I got it to scan. I found this by the grace of God. I have the same problem with the print cartridges. But I was attemting to get into my camera. I went to the 'My computer' Icon on Windows XP. Under that part of the file system, I have the "HP PSC 1600 series" icon under the scanners and printers. I double clicked this, and it allowed me to scan an image.
May 09, 2008 | HP PSC 1610v All-in-One Printer
Copy on my 2179 hp all-in-one
Hi Simoandson, The scanner failure message usually occures when the scanner bulb is not getting heated properly or the scanner bulb is defective. We can check with the issue by connecting the printer direcly to wall outlet and then lift the scanner lid and press scan or copy button and check for the scanner bulb is lit and scanner machinisum is moving fine under the scanner bed.. There is also a Firmware update released by HP that can be downloaded and installed to fix the issue: Here is the link: ========= http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&product=90809&os=228&lang=en ======= Just click on the link and in the download webpage click on the download only button and select save to save the download to the computer and once the file is saved make sure that the printer is turn on and connected fine and click on the file to install the firmware update to the unit If the issue still presists try to performe the steps in the below webpage: =========== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00787271&cc=us&lc=en&dlc=en&product=1138346&dlc=en&lang=en ======== Hope this will help you to fix the issue Regards, Barret.
Sep 02, 2007 | HP PSC 2175 All-In-One InkJet Printer
Hp psc 2175 scanner problem
Firmware problem with unit or a stuck keyboard. This is commomn on the PSC series which includes full scanner head failure. Unplug unit from computer to see if it will do it with no cominication to PC.
Mar 28, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 1600 InkJet Printer Logo
118 people viewed this question
Clive
Clive
