Question about MSI KM4M-V KM400 SocketA 333FSB 2DDR Aud+Vdo+Lan 3PCI+AGP8X SATA (I7061020)
Hi, need wiring/connection help if ya can thanks. power sw / reset sw / HDD led connections where they go on MSI KM4M - V via KM400 + 8237 chip based motherboard. ...cheers Cal.
  • 341 Answers
I dont know how to fix the Front Panel Audio Connector. And I dont understand what is ATX power switches. I'll tell you what wire i have: H.D.D. LED, POWER LED +, POWER LED -, RESET SW and POWER SW....
Hi!
You have to make make the four Front Panel Connection as shown below: -
(IDE LED is the same as HDD LED and Ground means negative '-')
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
May 31, 2011 | ASUS P4VP-MX Motherboard
How to connect jfp 1
go to www.msi.com.tw for MSI guide , it should show you your motherboards front panel intel connection guide , it should be like this
PSWITCH PLED Open
RESET HDD SPK
Jun 08, 2010 | MSI G31M3-L V2 Motherboard
Im having trouble hooking up the power switches and reset sw and hdd for msi km4m-v
Ok what you want to do is go over to the JFP1 Switch connection on the motherboard. It will be labeled and it has multi colors and 5 pins on one side ad 4 on the other. Starting with the 5 pin side the pin that does nat have a partner on the otherside where the 4 pins are stays empty. Immediately next to that are the two pins for the reset sw...notice the + and - symbols on them. On the wires that you have colored or striped is positive and white or nonstriped is negative (this may also be labeled on the little colored wires)...plug in the reset sw wires into those two pins. don't worry you won't damage the board by doing this wrong..you just won't get lights (at which poing you'd just redo it etc)...the next two pins over are for the HDD LED...plug those two in,...now the 4 pin side...there's the empty slot...then next to that is the power sw. Plug those two in there...next to that is the Power LED...plug those in there...note that the colors do not necessarily match up to their respective pin/wire colors so just read the labels and you'll be good to go...that's it...test by turning on and seeing the colos light up on your PC...if you notice the Hard drive indicater light blinking every time the Hard drive is in use then you're in good shape...takes practice but it's not too bad once you get the hang of it...Good luck!
ASpecialty4You.com
Dec 21, 2009 | MSI KM4M-V Motherboard
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Reset sw, power sw, and hdd led where do i put them on the motherboard
hello, your front panel connectors like reset sw, power sw, hdd led, you can search easily. a use of screw driver touch all front panel connectors, if any response of connectors connect it.
Aug 10, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
No power and I need wiring diagram for jumpers
Hi !
Via VT8237R is a chip that is on your motherboard. It does not determine your motherboard, and this chip is used in many different motherboards and producers of motherboards.
Try to locate the model and producer of your motherboard.
Usually it is written between PCI SLOTS or close to the RAM slots or close to the VGA Slot.
Finally, there is also possible to find a diagram written on the motherboard or close to the pins, with description of +/- pins.
Regards.
Apr 28, 2009 | VIA ASUS A8V-E Deluxe K8T890 chipset...
Connection issues for power led, reset switch, hdd led, m/b sw.
Hi carlmtclem,
See your first post, I have answered your question.
Jan 11, 2009 | MSI K8MM-V Motherboard
ACORP 6bx/via/zx81connectors
http://images.google.co.uk/images?gbv=2&hl=en&q=where+does+hdd+led+and+pw+led+wires+go+on+gigabyte+motherboard&btnG=Search+images
click on this link and it will take you to some images of various motherboards and where the leads go.
I hope this helps
Nov 02, 2008 | Intel Motherboard
WIRING CONNECTIONS TO MOTHERBOARD
All you need is in you motherboard's manual...
you'll see there a scheme of your motherboard and you can find how to connect them exactly.Or try download the manual.
Sep 04, 2008 | VIA Jetway V4MDMP MB AMD SKTA MATX/ KM400/...
Reset/power/led etc..lead connections
on most motherboard it is possible to read there to set the wires.
hope this helped a little.
May 15, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
345 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
