Question about Maytag Legacy Series Top Load Washer
I noticed machine trying to wash and spin at the same time.
Machine also makes a knocking sound at times when machine is washing. almost sounds like the knocking sound it makes when it finishes a wash cycle to stop. can also be refered to like a rod knocking in a car.
  • 1 more comment
  • bobbyhudson5 Dec 06, 2008
    noise is coming from motor area , there is nothing inside machine. I have always had to re-set machine on spin after it completed its wash cycle because clothes where still wet.as time has progressed the machine now makes knocking sound. i am thinking transmission problem or motor.
    Sounds like the right solution
  • bobbyhudson5 Dec 07, 2008
    I noticed the machine will spin for a few minutes , then start to slow down , then start spinning again. I think this is why I have to select extended spin once the cycle has completed so the clothes will be dry enough to put in dryer.
  • 3,037 Answers
What you should do, is remove the outer panel of the machine and then run it to determine the exact part that is causing the noise. the bolts will be on the back and/or bottom of the machine and the panel should pop off nicely. Once you do this, find out where the noise is exactly coming from and if you need help identifying the part, you can send me a picture otherwise just post back here.
I am guessing that the knocking noise may be caused by a loose tub weight. This would normally be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine. Warning: These days most washing machines have plastic tubs and over tightening a tub weight bolt can easily shear the bracket resulting in a new tub being required. Try loctite. Often, once a tub weight has come loose the plastic tub is damaged anyway especially if it isn't caught early enough
Posted on Dec 06, 2008
    Genius:
  • 1,239 Answers
Hi
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
thank you.please rate it..
  • 365 Answers
The inner layer may be have some compliant .when it runs at high speed it cannot be noticed ,it can be noticed at only low speeds since it also runs together with it.so tightly fix the inner layer
    Sergeant:
  • 306 Answers
Lots of this design washer do this. The brakes have grease residue from the spin tube brearing this is making them stop the spin tub too fast. The intertia of this is the thump. To properly resolve this the unit will need to be dissasembled and the brake pads cleaned and the drum cleaned.  This sounds like the brakes have gotten some residue on them and are grabbing way too hard. The banging is the tub stopping too fast and the torque from this makes the tub bang into the cabinet. Just one bang at the end of a spin.
    Sergeant:
    Champion:
  • 304 Answers
Check the washer for any stuck object inside. it is possible that there was a object there the giving this unusual noise on the machine
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Air power bubble washing machine model -dwf -1150p
Daewoo Airpower Bubble Wash Machine Model - DWP - 1150P
My Machine does not want to spin anymore. It makes a knocking sound and then stops and starts filling up with water again, then drains it and wants to start spining and again makes a loud knocking sound and the repaets the already mentiond sycle. Can you help me with this problem? Does Daewoo not have service centers for these machines?
Apr 21, 2013 | Washing Machines
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Washing machine makes knocking sound
Hi, it sound like your machine overloaded, try smaller wash, and check to see if it does same thing, let me know, if it continues with small wash. good luck.
Aug 08, 2009 | Washing Machines
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
I have WP Duet HT front laod washer. Model #-GHW9250ML1 Type 199 080 SC/WG Problems - 1. while the tub is spinning it makes a knocking sound. When the tub slows it knocks louder. What is the problem and...
COULD BE LOOSE BASKET OR REAR BEARING LEAKING OR SIMPLY SUSPENSION SHOCKS BROKEN ,, EVEN SHOWS 1 MINUTE JUST ESTIMATE TIME NOT READY TO SHUT DOWN NORMAL ON DUET MACHINES
Nov 29, 2008 | Washing Machines
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Knocking sound in agitator
Your Agiator "Dogs" maybe stripped these hold the agiator in the wash cycle place you han on top of the agit. and try to turn it clockwise then go back counter colkwise is it feel like it is grabbing or just free spinning??
Jan 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
