Question about GE Monogram ZICS360NR Bottom Freezer Refrigerator
My Monogram ZIS 42D Lights do not function, Freezer or frig
I have a schematic, Pub No. 31-51404. I can not find the location in the refrigerator of the light switch or the fuse listed after the door switches in the schemtics.
I am looking for publication that will show me where they are.
Sea Breeze
  • 4654 Answers
SOURCE: GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
Posted on Oct 21, 2007
docjohn174
  • 943 Answers
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Posted on Oct 15, 2008
Greg20
  • 149 Answers
SOURCE: I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Posted on Jun 12, 2009
SOURCE: I have a monogram zis 42d side by side the freezer
I have this same problem. Now, the freezer will not get cold enough, but still water runs down into the ice bin and just turns into a big solid block of ice. The water is dripping from the top of the freezer compartment. I have disconnected the water coming to the refrig to not allow it to make ice, but still happening. Please post if you have found a solution? Defroster issues?
Posted on Jan 26, 2010
  • 2468 Answers
SOURCE: GE Monogram won't freeze food
your evaporator coil in the rear area behind the panel is iced up and blocking fan air flow to the freezer compartment
Posted on Jul 25, 2010
Freezer works fine but refrigerator side is not cooling
yes ok. try the control to your right and it should say like freezer colder and warmer. by making the freexer a little warmer it will make the ref. colder. u r just turning a baffle so more cold air from the freezer will go into the ref, to make it colder.. ok
Feb 13, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
Frig is running hard but temp is higher then set in both frig and freezer
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 08, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram refrigerator does not cool. The fan on top was loose and not spinning. I fixed that, and it now spins properly, but he freezer and frig will not cool at all.
I need you to pull away from wall and remove cover over compressor and feel compressor for heat. If too hot to hold hand there or if warm or just cool. Tell me what you find. I would like to help you solve this if you like. Sea Breeze
Feb 21, 2010 | GE Monogram ZISS480NRSS 48" Built-In...
I have a monogram zis 42d side by side the freezer section works but in the defrost mode the unfrozen ice runs down the sides of freezer and into ice cube storage container, I have cleaned out the drain...
Nov 09, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
I have a monogram ZIS420 the freezer works fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 24, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Water leaking from top of freezer into icemaker and right side of freezer. Coils, etc. are clean.
Is the water condensing and winding up in the ice maker or is there an actual leak in the ice maker water feed line?
Jul 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Ge Monogram ZISS420DMAS compressor and fan not running
ICE CREAM WON'T FREEZE
The ice cream does not freeze, it stays soft. I have a GE Monogram 42" Built-in-Side-by-Side Refrigerator.
Nov 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram ziss480dmss Side-by-side refrigerator
no replace the door control bd or check for a loose or bad connection on the control bd also in an abstract sense one of the freezer door switches could be bad ones for the freezer light ones a safety for the door dispenser sys but that would be rare but possible
Mar 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram ZICS360NR Bottom Freezer Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
