52inch RCA wont turn on with remote or power button on set.
    Sergeant:
    Champion:
  • 248 Answers
Try to reset Do this by unplugging the power cord for 4 hours. Then plug it in directly to a good outlet.
If the lamp is still blinking it means the protection circuit is detecting a failure in the main power supply. It would take around $400 to repair. It would need a tech to take some measurements in determination of the exact parts that have failed.
Posted on Dec 06, 2008
    Sergeant:
  • 306 Answers
Did you reset the tv? Do this by unplugging the power cord for a full 4 hours.  Then plug it in directly to a good outlet.
If the lamp is still blinking it means the protection circuit is detecting a failure in the main power supply. Cost of repair will be in the neighborhood of $400.  It will require a tech to take some measurements in determination of the exact parts that have failed.
  • AbdulRahiman S Dec 06, 2008
    else Your main board is bad. You could have it replaced, but only if it's REALLY worth it.
    else try tis.. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced.
  • 13,433 Answers
Check the fuses on the power board if your tv is noting powering on at all. if the fuses are fine, I would suggest contacting a repair tech the problem may lie in the power board but its best to get a professional to help you since this is a high voltage device.
  • 365 Answers
Try to check whether the power is delivered to the system.if not it may be due to some circuit failure or due to the power cable compliant
  • JITHIN ANTONY Dec 07, 2008
    have you checked all
  • JITHIN ANTONY Dec 14, 2008
    does the problem solved
    President:
  • 1,314 Answers
Have you tried unplugging it for 5 minutes or so, then plug it back in.
I have an RCA tv that the parental locks are set on and now the remote wont turn the tv on
you probably need to go for a universal remote , and check as the problem might be on the existing remote may not be working and then using the universal remote , u can undo the changes you have done .
Dec 14, 2014 | RCA 27" Tv Sdtv Universal R.c. connections...
Need code to program rca remote to my rca t.v.
rca technical support is sadly lacking... I used youtube to search for the remote model number to find a video that taught me how to search with the remote to get the proper code. ..try this, for tv hold tv button and power button on remote till power button turns red, next point remote at tv which is already on and press the play button on the remote. This causes the remote to try 10 codes. wait for the power button to quit winking at you, if the device (tv) turns off, it means that one of the 10 codes was correct. If the device stays on press play again to try the next set of 10 codes. It may take several tries. When it responds by turning off, we need to back up to the exact code by pressing the << reverse button one press at a time. When power comes on you have found the code. Now use the stop button to lock it in.:) I'll include a link to a vid. Programming an RCA Universal Remote If this helps please 'like' my answer.:P Mikee
Oct 13, 2014 | Televison & Video
Power button on my rca tv wont turn on sometimes
A number of possible reasons for this---failing part in set or even bad connections on main board in the set----model listed is prone to going dead with high pitched squeel etc.
Oct 31, 2012 | RCA TruFlat 27F520T 27" TV
When i press the power button on the remote to turn my 52inch tv on it doesn't start and makes a clicking sound as if its trying to come on
What is the brand name to your TV? Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 25, 2012 | Televison & Video
Hello I have a universal remote control for tv sanyo but I lossing de manual instruction and Iand ree program my tv. only I need how cam progarm my remote control pleaswed thanks.
Here is the steps on how you can reprogram your RCA tv remote control:
1. Turn the television on by pressing the "Power" or "On" button that is located on the set.
2. Press and hold down the "Code Search" button located on the RCA TV remote. 3. Press the "TV" button on the RCA TV remote. Once you press this button, you can release the "Code Search" button
4. Start pressing the "On/Off" or "Power" button that is located on the RCA TV remote. Keep pressing the button until the television shuts off. 5. Press "Enter" on the RCA TV remote to save the code on the remote. The remote will then control the television.
Apr 07, 2011 | RCA Universal Remote Control
52inch rca rear projection power button turns green but tv will not turn on will replacing the capacitors repair this problem
Often it will, But the Flyback transformer is also famous for failing in that Model which can cause the same symptom. Caps should alwasy be tried first with that model.
Oct 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture (fan& bulb do not come on) but there is sound
I have a RCA 52inch D52w136D, the power button blinks three times, but nothing happens no picture or sound
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca d52w20 52inch tv doesn't want to turn on
Well not knowing this particular unit myself, i would strongly suggest troubleshooting the users manual, which can be downloaded here.
http://tv.rca.com/en-US/UGConfirm.html?modelno=D52W20
Jan 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power on/off
I had the same problem with an older model, try changing the batteries in the remote.
Dec 31, 2007 | RCA D52W19 52" Rear Projection Television
TV wont turn on?
this product has a bunch of exotic semiconductors that only a tech could replace in my parleyance its called NECO
Dec 08, 2006 | RCA 27R410T 27" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
