Question about Delta Faucet Company Classic Collection Venetian Bronze Toe Operated Tub Dr
I changed the o ring on delta bathroom faucet and now it will not
Shut off
  • 1 more comment
  • Joe Neff May 11, 2010
    Okay, How old is the faucet? Is it a single lever or a double handle? Hot or Cold or both do not shut off? Send more info and I'll try to assist.....Joe
  • danny ramirez May 11, 2010
    need more
  • James Feragola
    James Feragola May 11, 2010
    I don't understand the question. Is it How do you change the O-ring?
  • 297 Answers
Need alittle more info so i can help you.
Posted on Jul 31, 2009
  • Bill Johnson Jul 31, 2009
    need alittle more info so i can help you.
Hi there i have a lunnar delta 2004 640ew im trying to find a new replacement bathroom sink have you got any ideas where i can get 1 from many thanks tim
ring around plumber whole sale suppliers and explain what you want
they are in a position to advise you where or if what you want is still available
Jul 19, 2016 | Moen Bathroom Sink Faucet - 4-inch...
I have had my Delta bathroom faucet about four years. The hot water side drips. Can not get it to stop. It is one faucet with hot and cold handles with all sitting on a small platforum. The platforum is...
Go to delta website, take a picture of faucet with your cell phone and send. They should be able to identify and send you the parts. Meanwhile you'll have to turn water on and off from the emergency shut off valve under the sink. If it looks like the picture, it's probably the rubber seat and spring. If you don't want to wait go to your local "hardware" store. There may be someone there to help you. Bring the stem or cartridge, along with the rubber seat and spring. Don't use cold water while stem is removed. Turn cold off as well to prevent a mishap.
Apr 23, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
My Delta type kitchen sink handle is loose and keeps shutting water off. I have to turn it up a lot to keep it going. I could remove Red / Blue plug and do not know what to do beyond to tighten it?
Inside the handle of a Delta kitchen sink faucet is a small setscrew. You need an 1/8th inch allean wrench or Delta faucet tool to lossen the setscrew. Rotat the screw about 3 full turns counterclockwise, this should be emough to remove the hnalde. Under the Delta faucet handle is a white plastic ring with four notches. If you have a Delta faucet tool, you place it in two of the notches and slowly turn the ring clockwise to tighten the Delta ball assemby. This will keep the handle from moving by itself. If you do not have Delta faucet tool, use a pair of needle nose pliers in stead.
Oct 12, 2010 | Plumbing
Leaking bathroom faucet
These single handle faucets tend to need the internal "O - rings" changed every couple of years. Find your model # and take it to Home Depot or Lowes or some similar store and find the "kit" compatible with your faucet. Some kits have a cartridge, some have springs, O - rings, etc. The kit will have instructions on how to remove tha old one and install the new one.
May 24, 2010 | Delta Model 470: Signature Kitchen...
"Mintcraft" faucet any good?
Hi, If you asked me, I bought from amazon/ebay depending on reviews... (that way you cant buy something not good). so.. take look Were doing more than just throwing away the key . I hope this helped you. Cheers
Apr 26, 2010 | Mintcraft L5860-03-07 ATLANTIS POLISHED...
Bathroom sink pipes came apart and flooded our bathroom. cant find shut off valve to sink
Hi, W/D here.
Almost always, the shutoff valves are at the wall where water is supplied to the faucet. If the problem is with the drain piping, and the faucet valves don't leak, you don't have to shut off the water. Simply replace the drain piping and tighten it up. If you need any repair parts, you can get them from any hardware store. Please repost if there is anything else that I can help you with.
Good luck, and best regards,
--W/D--
Aug 13, 2009 | Delta Plumbing
The unit has a croosbar connecting the hot and cold water. How do you remove the crossbar to replace the faucet
Do we want to remove the faucet from the top of the sink?
First shut-off the water via the two valves under the sink. Then un-thread the hoses from the bottom of the sink. Sometimes it is possible to do with ordinary house tools but more than likely you will need to purchase a basin wrench for about $10. This wrench will allow you easy access to the bottom of the faucet.
Then, using the same wrench, un-thread the nut that is threaded on the same threads as the hose. This nut if probably pretty tight and will take some effort.
Replacing is the exact opposite except when replacing be sure to use plumbers putty on the bottom of the faucet as a means to keep water from running under the faucet base and ruining your cabinet.
May 21, 2009 | Delta Faucet 2520 Classic 4'' Centerset...
Valve in Delta faucet closes as water warms up
Yes, you are on the right track, but Deltas use a fancier kit inside them. It is quite a bit pricier than an O ring, but will solve the problem. It is not hard to install at all.
Jan 10, 2009 | Delta Faucet Delta 156-WF Victorian Single...
Delta Faucet Company Classic Collection Venetian Bronze Toe Operated Tub Dr Logo
117 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
