Question about Sony Dvcam DSR-PDX10 DV Digital Camcorder
Black and white playback on television screne
When the camera is connected to the TV, playback on the TV is black and white. Playback on the camera LCD is normal and in color. I have tested the problem in the following ways: The television plays other programs and DVD's in normal color. The s-video and the RCA/yellow head video cable produce the same result. Different tapes, some previous some recent, all play black and white on the television, but in color on the LCD. The camera is functioning normally otherwise. I have had it three years and use it fairly constantly. Could this be about cleaning the heads? Please say it is.
  • cameron snow Feb 15, 2007
    You were exactly right.
    I couldn't believe it at first, but when I looked at the TV manual, I found that the color system control is a tiny button next to the RCA input. I must have hit it inadvertently. Thanks so much.
    -snowwhite
    Scholar:
  • 168 Answers
Select the correct color system in your tv. probably the system which was selected in your tv did not match that of your video cam. good luck!
Posted on Feb 15, 2007
NOT GETTING COLOUR FROM CCTV DVR TO TV BLACK WHITE
Missing information alert. What is meant by "to TV black and white"? Are you saying you can't get playback on a black and white (and therefore old, analog) TV set? What connection set up are you using between recorder and the playback TV? At first glance it would appear you might need a digital to analog converter to process the DVR output prior to feeding it as a SD (standard definition) signal into your TV set for mmonitoring. thanks for clarifiying your question, including a description of your setup.
Dec 23, 2012 | Home Security
Im trying to playback on tv when i conect leads to tv picture is black and white not colour any sugessttions
1) Check that the pictures are in colour and not black and white.
2) Make sure the cable is fully home both in your camera and the tv socket.
May 24, 2011 | Cameras
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
Toshiba VCR. It records OK but playback is black, white shaky
What do you mean by "records OK"? It sounds to me like you are not getting a signal to record. I had this problem before, as well. There are two things I recommend you try. The first is that (if you are trying to record over-the-air tv, you will need a digital television converter box connected directly to the vcr. If you already have one and are sure that it is connected correctly, you may also try an RF modulator. When I got my new vcr, it wouldn't work at first. I eventually found out that I would need an RF modulator in order for it to work on my tv. I hope these suggestions help. Good luck! Sincerely, Der Strom
Apr 26, 2010 | Aiwa HV-MX100 VHS VCR
My lumix camera in playback mode has on screen tv
If you can get into the menu and find "reset" you could return the camera to factory settings.
Feb 21, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Playback on TV is in black and white
Only had my device for a few days now and dont actually have the tv dock yet. However I'm gonna assume you have to go into the display settings from archos. Worth taking a look guys!!
Jun 01, 2008 | Archos 605 WiFi Digital Media Player
Rolling picture on TV while playing back Hi8 tape on TRV460
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
May 23, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
JVC dvl 9700 playback on tv is black & white
You can get the sound to play by hooking up an additional cord to the audio jacks - the same as you would do if you didn't use the s-video. I am still working on the b & w issue
Nov 27, 2007 | Video Cameras
Black and White menus and playback
check in your menus to see if your can change your scart output settings, i.e. rgb
Feb 26, 2007 | Panasonic DMR-E50 DVD Recorder
Sony Dvcam DSR-PDX10 DV Digital Camcorder Logo
287 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
