Question about Linksys Wireless-G WRT54G Router
Reset the security code for the router
I would like to reset the security code ( pass word for the router) in order to set up the wireless access for laptops from within my home
Theres a reset botton at the back of it. use pin to reset it
Posted on Dec 06, 2008
Pass code is not working
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 06, 2011 | D-Link DIR-615 Wireless Router
Tip
Where can I find the WEP key on my router? Router security key, router password
If you have a wireless router at home you will need to have a WEP key setup on your router. WEP stands for "Wired Equivalent Privacy" and WEP is a security protocol used to secure wireless networks. When you setup a router for wireless, you normally specify a key(password) so anyone that wishes to join your network has to enter the key. You normally set the WEP key during the router setup phase. You may have set it up and forgot it, or want to reset it. In this article I will go over the steps to find out the WEP key or change it. Your router may use a different security protocol than WEP so don't worry, you still need a KEY in order to access the network.
-On most routers(reference your user manual) you can access the router configuration page by going to the gateway address. The gateway address is the IP address assigned to your router. In a lot of the cases, this address is 192.168.1.1 but depends on your router.
There are a couple of ways to find out this IP address.
-Reference your router manual
-In Microsoft Windows, go to Start > Run and in the run box type "cmd" or "command". A black DOS windows should open. In this window, type "ipconfig /all". Look near the top and you should see a "gateway address" item. This number is the ip address of your router.
Once you know your gateway address, open up your internet browser as if you were going to go to a website. In the URL(address) bar, type the gateway address and hit enter(see image below). A log in box should now show. Again, reference your router manual if you do not know the administrative password. Enter in your password and username.
Once you log in you now have access to the router settings and you can configure what you please. What we are looking for in this article is the wireless security settings. In the wireless security settings page you should be able to see the password for your wireless network and change it. If you see no password go ahead and set one up.
**You can also look around and modify other settings. You can change the wireless security, give your wireless network a name(SSID field) and even with some routers have built in testing features to test the connection at home.
I would recommend that if your router has a default password for admin/configuration access, that you go ahead and create a new one. The default router passwords are usually very simple and this information can be easily found on the internet by anyone. People who set up home networks tend to leave this as is and it is a security risk.
TIPS
-If you can't connect to the router and you know the gateway address, try plugging the computer into the router directly using a Ethernet cable(LAN/patch cable). If you are still having trouble, you can perform a power cycle. Turn off your modem, router and computer. After 10 seconds turn on your modem, after 30 seconds turn on your router and after another 30 seconds turn on your computer. Try to access the router now. This also helps resolve other quirky router issues.
-Make sure all the network cables, phone lines(if using DSL) and coaxial cables(cable/Broadband) are plugged in and secured firmly.
-If you set up a password and username for your routers administrative access and can't remember it, you can reset the username and password back to factory default by performing a factory reset. On most routers this can be achieved by pressing and holding the small reset button on the back of the router for 15 seconds. Please reference router user manual for more information.
I hope this article was informative. Thanks for reading.
Regards,
G33k
Keywords
Where can I find the WEP key on my router?, How to reset router WEP key, lost router security key, where can I find router password, how to reset router password, where to find router security key, how to configure router security, how to configure router password, how to configure router WEP key, lost WEP key, reset WEP key, can't find my pass key, lost router pass key, lost router wireless pass key, how to reset router passkey, how to obtain router passkey
on Jun 01, 2011 | Computers & Internet
Cannot get my wii to connect to my charter wireless
To connect a Nintendo Wii to the Internet using a wireless connection, please follow the steps below:
  1. On the Wii console's main menu, click on the Wii button in the lower left corner.
  2. This will take you to the settings screen. Click 'Wii Settings'.
  3. In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the Internet button.
  4. Select 'Connection Settings'.
  5. Select an open connection, indicated by None.
  6. Select 'Wireless Connection'.
  7. Select 'Search for an Access Point'.
  8. At this point, the Wii console will search for any identifiable Access Points nearby. Once this search is completed, you will be directed to choose the Access Point that you wish to connect to, as shown. Click OK to display the list of available Access Points.
  9. Select your Access Point from the list of available Access Points. If your Access Point is not displayed, contact your wireless router manufacturer for support.
  10. Click Save followed by OK to save your connection settings.
If your connection appears as a closed padlock, then the Access Point requires a security code or pass phrase. The security code or pass phrase can usually be found on the security tab of your wireless router settings. If you do not know the security code or pass phrase and do not know how to login to your router to get it, contact your wireless router manufacturer for support.
If your connection signal appears yellow or red, the stability or strength of the connection is not optimal, contact your wireless router manufacturer for support.
If you still have problems, call them at: 1-888-438-2427.
Mar 28, 2011 | Video Game Consoles & Games
How do I set my admin pass code
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. If you want to set admin password of router then go to system settings in router and configure admin password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 14, 2011 | Computers & Internet
Trying to connect to my net gear router, keep asking for a security key, and all I can come up with is a pass phase
Jan 10, 2011 | Linksys WUSB100 Wireless Adapter
I have up graded my Sony vaio with windows 7 and my router asks for a pass word. I never loaded a pass word. I'm using another computer to send this message George
You need to reset your password.
For that first connect your router to computer with ethernet lan cable.
Then you can access it with default link.
http://192.168.15.1
or
http://192.168.2.1
type user as "admin" and password as "admin" or blank or "password" or "1234" then you can see configuration page of router.
If you are not able to access it with above link then check your lan card property ip address gateway ip is your router ip access with it.
If still same then RESET router to defaults.
You can RESET it with RESET button it is in back side of router press it for 10 seconds so all settings defaults.
Then you can access it with above link.
Then click on wireless and enable it there WEP pr WPA or WAP security add new password and save settings then restart router.
Then you can connect with that new password.
If you need to RESET router you can configure it with below method.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Mar 26, 2010 | Belkin (F5D7230-4) Router (587009)
Need a securty code
Regarding your concern, please note that in order to get the network key/password on the NETGEAR router (MODEL_NUMBER), we need to login to the router's web interface using any computer which is physically connected to the router.
Please follow the steps on a computer connected to the router using an Ethernet cable in order to find the network/security key:
1. Open the browser (like Internet Explorer, Mozilla Firefox, or Safari).
2. Access the router, usually by typing 'http://192.168.1.1', 'http://www.routerlogin.net' or 'http://www.routerlogin.com' in the address bar.
3. When prompted for Username and Password please enter Username as 'admin' and Password as 'password' (please note that both Username and Password are case sensitive).
4. Click on Wireless Settings' under Setup from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the pass phrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the NETGEAR router's wireless network.
In some cases, for security reasons the pass phrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Feb 07, 2010 | NetGear WGR614 Router
Netgear MGT624: My netbook shows its connected to my router but
Re4place your Wireless Access code as set up with router control program. Often wireless access is denied when mistakes are made with this pass code. Just replace whatever code you have with another (simpler?) code or even going to "None" for Security. To try and establish comm through the router, if it succeeds with no security try again with perhaps WPA-[TKIP] coding.
Dec 12, 2009 | NetGear WGT624 Wireless Router
Need to know how to reset password so neighbors can"t access my internet
http://192.168.15.1
this is defaults link for acces belkin router
then go to wi fi security then u see encrption security then u can reset pasword easily.
May 07, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys Wireless-G WRT54G Router Logo
93 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
