Question about Philips Magnavox 27MS343S 27" TV
Pin cushion falt
I have a problem in my philips tv model 29 inch PT7322 56R picture shrink from the center i mean horizontal whidth or pin cushion falt can u suggest me what i do and where in circuit i dont have a cicuit of this tv
this a request kindly send me circuit dai gram of this model and guidance also
thank sohail
    Champion:
  • 225 Answers
Circuit diagrams are available online from 5-20 dollars. I doubt it will do you much good, as you will need to be an expert at tv repair in order to read the diagram, and trace the problem. It sounds to me like a bad capacitor near the horizontal deflection circuits, or a resistor near the pincushion adjustment could have blown. If you really want to learn how to fix your tv, you should visit some learning websites that explain the different areas of a tv circuit board and their functions.
Posted on Dec 06, 2008
Picture shringking 2 side horizontaly sony tv
Pin cushion section circuit fault. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 25, 2014 | Televison & Video
My LG Super Slim 29"
You don't have a deflection yoke problem, you have a pin cushion problem. Check the pin cushion transistor.
Jul 22, 2011 | NetTV DTV-29XF3 29" TV
Tv picture shrinks
This is a common problem on certain models of Philips Magnavox TV sets. The most common symptom is the screen will shrink and expand over and over. After the TV heats up for a while the video will work like normal. After a few weeks or months your TV will eventually stop working and not have video. You can get complete parts and instructions from www.TvRepairKits.com
Nov 17, 2009 | Philips 9P6031C 60" Rear Projection...
Picture shrinks toward the center of the screen
Common problem with Philips sets.
If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original chips, email/phone support, etc.
Jun 11, 2009 | Philips Televison & Video
Picture shrinks to only show top half
May 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture shrinks horizontally every few seconds.
You are changing parts in the wrong circuit. The problem is in the vertical circuit. Look for the vertical IC and resolder the pins first. It should be an LA7837 or something similar. Also, check the 100ufd and 47ufd caps in the same circuit.
Keep us posted.
Dan
Jan 19, 2009 | Panasonic CT-20G11 TV
Phillips Magnavox 60" model ptv835
Recently had same issue and after EXTENSIVE SEARCHING found all three ICs and replaced them. TV works perfectly, also, replaced convergence ICs at same time. The one 16-pin IC for the regulation ckt. is $49.95 the other 16-pin IC is $19.95 and the 8-pin opto is about $10. This price is for a minimum qty. and must have a business for quote.
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
NO PICTURE HAS SOUND
When you say small do you mean shrunk up top and bottom as well as from side to side. You definitely have a deflection problem either horizontal or vertical.If the picture just shrunk top and bottom you have a vertical deflection problem. Do you have the service manual for your model? If not let me know and I will email you one. Describe the shrinking issue a little more and I should be able to give you some guidance.
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Shrinked picture of 29 inch television.
It is a pincushion problem. There is a bad cap and or a bad diode in the horzontal section.
Oct 29, 2006 | Toshiba 27A51 27" TV
Picture Shrinks
It is in the power supply or I would guess most likly in the horizontal sweep section of the tV set. MOST of the time, if the power supply is going lower in voltage, the set will shrink in width,BUT will also shrink in vertical size. If this is not happening, then I would say it is in the horizontal drive circuit. This is not a circuit a user should be experimenting with, as this is the HIGH VOLTAGE circuit and can pack a mean punch! Please if the sets less the 4 to 5 years old you may want to concider an estimate or replacing the set. Its all up to you. GOOD LUCK
Oct 07, 2006 | Philips 8P6034 TV
Philips Magnavox 27MS343S 27" TV Logo
220 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
