Question about Acer Aspire 5102WLMi Notebook
TRYING TO CONNECT ACER MONITOR TO MY DELL LAPTOP
I TRIED TO HOLD DOWN fn ON THE KEYBOARD AND HOLD DOWN THE MONITORS ON THE KEYBOARD ON TOP AND STILL DOES NOT TRANSFER TO THE ACER MONITOR
  • tanvierahmed
    tanvierahmed May 11, 2010
    try it by presseing this keycombination 2 , 3 times...
Are hp laptop and dell monitor compatible?
Without knowing the model numbers of both it could be impossible BUT if you have a connection on the computer that you can hook the monitor to, the F4 key is the one that switches from the laptop screen to the external one. Hold down the key that says Fn and while holding press the F4 key above the number keys on the top row at the keyboard. You should get some activity on the monitor.
Jun 24, 2014 | Dell E176FP 17" LCD Monitor
Dell 1703fpi
Dell 1703fpi LCD monitor,
http://philadelphia-pa.americanlisted.com/computers/dell-1703fpi-17-lcd-monitor-vgadvi-usb-hub-50-phoenixville_21225579.html
I got that part Dan.........
What I need is what Model Number of Dell Inspiron it is.
This is on the Bottom of the Inspiron laptop.
Why?
Because I do not know if the Dell Inspiron laptop you have, has a DVI port, or a VGA port; for an external monitor......
Generic information while I wait.........
Example of Digital Visual Interface port, and corresponding cable,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Example of Video Graphics Array port,
http://en.wikipedia.org/wiki/VGA_connector
Can be on the side, or back of laptop.
Laptop OFF, monitor OFF, connect the matching video cable from the external monitor; to the laptop.
Now turn the laptop on.....
By factory default settings, the display should now show on the external monitor. (Dell 1703fpi)
No?
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external monitor
3) External monitor ONLY
Press, and hold down on the Fn key. (Usually 2nd key from left on bottom row of keyboard)
AT THE SAME time tap once on the Display Toggle-Over key.
Which one is that? Dunno.
Laptop model number was not stated.
For a Dell Inspiron though, it's usually the F8 key.
(F1 through F12 keys at the top of the keyboard)
Hold the Fn key down, and at the same time tap once on the F8 key.
Still no?
Hold the Fn key down again, and tap once more on the F8 key.
IF, F8 is the correct key for Display Toggle-Over, and there is no display on the external Dell 1703fpi; then I suggest you have a problem with the video chipset; on the motherboard.......
Awaiting reply in a Comment.
Regards,
joecoolvette
Jul 03, 2013 | Computers & Internet
Dark picture on monitor
Occasionally, you may find your laptop's monitor is too dim for your liking. A normal desktop computer's monitor has an on-board menu system that lets you adjust the brightness and picture control settings as you please. A laptop monitor has no such controls. You can adjust the brightness of your laptop monitor using your laptop's keyboard.
1. Press and hold the "FN" key on your laptop's keyboard. This is the "Function" key, which operates much the same way that the "Shift" key does: It allows keyboard buttons to be used for multiple purposes. It's located in the lower left corner of most laptop keyboards, next to the "Windows," "CTRL" and "ALT" keys.
2. Look at the top row of keys on your keyboard for a key with a tiny triangle pointing upwards and the symbol of a sun on it. This is the "Increase Brightness" key. With the "FN" key held down, press the "Increase Brightness" key. On most laptop keyboards this is the "F7" key, but it varies depending on the model.
3. Continue to hold down the "FN" and "Increase Brightness" key until your dim laptop monitor has reached the level of brightness you require. A laptop monitor can only get so bright. It will stop at its highest setting.
4. Release the "FN" and "Increase Brightness" keys. You have now fixed your dim laptop monitor.
I hope you find it very helpful. Thank you for using fixya
Aug 17, 2011 | Acer Aspire 5610-2089 Notebook PC (ACER...
My HP Pavillion M70 monitor is saying "video cable connected?" when I try to use the monitor. I am trying to output my laptop to the monitor because my laptop screen is wearing out, but I cannot get it to...
go into the BIOS settings and tell it to use the LCD/Monitor as a display.
or
press fn key+(F5 or F7 or F8) 1x or 2x or 3x.....
Fn key combination. The Fn key is located at the lower left of the keyboard, normally between the CTRL and the ALT key. Toshiba uses Fn-F5 to toggle between the laptop LCD and an external display. IBM or Lenovo uses FN-F7, Acer varies with the model, using Fn-F5, Fn-F3, Fn-F8, Sony Fn-F7, Dell Fn-F8, HP or Compaq, Fn-F4. There are variations with the age of the laptop and not all manufacturers have standardized on a key combo across the whole range, but you can usually figure it out from the little graphics on the function keys that line the top of the keyboard.
Aug 25, 2010 | HP Pavilion M70 17" CRT Monitor
Acer monitor wont exit power save mode. Ive tryed 2 different monitors. 1 the acer the other a dell and didnt work on both, but the dell works fine as long as its not that pc. I removed the motherboard...
Assuming that it is an "external" monitor, and not the built-in LCD screen in your notebook, you have to tell your computer which option you want:
* output only to internal screen
* output only to external monitor
* output to both internal & external.
Look for a BLUE-coloured 'FN' key on your keyboard, and a button that cycles through the above 3 settings. Push that button while HOLDING the 'FN' key down.
If your computer is set to "internal-only", then the external monitor will _stay_ in "power-save" mode, although the monitor will work fine if connected to some other "desktop" computer.
Apr 02, 2010 | Acer Aspire One PC Notebook
The screen is not coming on at all. i connected
With the external monitor connected, try holding down the FN key and pressing one of the F keys at the top of the keyboard that has a Monitor icon on it. This should turn off the external screen and show the laptop screen. If you press it a 2nd time, BOTH screens should show up. If still blank, Press again until the External Monitor comes back on. Then go to www.dell.com/support and go to Drivers for your Model. Then download and re install the VIDEO or DISPLAY Drivers. This should fix it if its a missing driver. If STILL no display on the laptop, call Dell.
Oct 21, 2009 | Dell Inspiron 9300 Notebook
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Monitor not working
On the laptop, you'll need to change the video mode so that the laptop knows to send the signal out the VGA port. The two common ways of doing this are to find the Function key and the monitor toggle button. It's usually one of the F-Keys at the top of the keyboard in combination with the Fn key at the bottom. Hold the Fn Key and press the toggle key a time or two with the external monitor connected. If this doesn't work, or you can't find the keys, leave the monitor connected and reboot the laptop. When the laptop boots up, the OS should detect the external monitor and automatically turn it on when the OS boots.
May 14, 2009 | Acer Computers & Internet
My screen of my laptop acer aspire 5670 is smaller
3 possible solutions
1. There is a monitor mode to display correctly when connected to a larger monitor, look at the top line of keys on your keyboard for a key with 2 monitors on it. You usually need to press the FN (Function key, bottom left) hold it down then press the monitor at the top
2. Your display drivers are incorrect see http://www.howtofixanything.co.uk/howto-52.html to update your video driver
3. Try starting Internet Explorer and click Tools (At the top) --> Windows Update
See if any updated Video Drivers are available
If you cannot see tools at the top in the menu bar pres the <alt> key once
Jan 13, 2009 | Acer Aspire 5670 Notebook
Can dell monitor connect to damaged screen on acer laptop
It shouldn't be a problem connecting an external monitor to the laptop using a vga cord. Once connected you will have to use the "Fn" button on the laptop and the corresponding "F" function button located at the top of the keyboard of the laptop that will allow the laptop to switch from both monitors or just each one individually. Usually it is the "F4" button.
Good luck
Jun 27, 2008 | Acer Computers & Internet
Acer Aspire 5102WLMi Notebook Logo
132 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
