Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Power button not turning on - Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
  • lukab75 Mar 07, 2009
    tryed it and still no power
  • 24 Answers
Assuming the machine has power, The first thing to check is that the front door is closed. There is a microswitch to the right of the brew group that gets depressed by a tab on the top of the door. If the door is closed then the door microswitch would be the place to look for the problem.
Posted on Dec 16, 2008
My hp 6300 front panel lights are not working...how do i fix
Try below resets, one after the other if issue persits.
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
May 30, 2011 | HP Officejet 6310 All-In-One InkJet...
Tip
HP Office Jet All in One : Resetting Steps
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Rizwan
on Jan 19, 2010 | Office Equipment & Supplies
Ink system failure, error 0xc18a0001. happened suddenly, adviseme to turn it off, have turned it off, and same problem persist, it will not function a all.
Resetting the printer fixes most of 0x errors. Try next reset if the 1st one did not work.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards
Riztech
May 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
On printer bling bling cannot do anything
Please try below resets one after the other if issue is not solved by 1st method.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards
Riztech
Jan 12, 2011 | HP Officejet 5610 All-In-One InkJet...
Scanner Failure Cycle Power and try scanning again. Warming Up
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards
Riztech
Jan 11, 2011 | HP 7210 OfficeJet All-In-One Printer
When I turn my hp g85 on,I get the following message:initializing,then a sound then press enter to allign cartridges then the printer flashes off &on and turned off by its self.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
  • Press and hold "Enter" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
Oct 30, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
MY HP OFFICEJET 6 310 ALL IN ONE INKJET PRINTER IS FLASHING RESET POWER
Please follow below resets.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Riztech
Oct 24, 2010 | HP Officejet 6310 All-In-One InkJet...
I hooked the printer up and all the lights are blinking it says reset power...what do i do...
Try the below resetting steps
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Rizwan
Aug 19, 2010 | HP Officejet 6310 All-In-One InkJet...
Officejet 5610 All-In-One InkJet Printer: error 0xd0620130 reset power...
Please try the below resetting steps
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Rizwan
May 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Worked yesterday, now will not turn on!
  • Try connecting the printer directly to wall outlet without surge protector.
  • If the problem exists reset the print, see below steps to reset it.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Riztech
May 02, 2010 | HP Photosmart 3210 Printer
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
100 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
