Question about HP Photosmart 735 Digital Camera
Camera not taking pictures
I just got a HP 735 cxamera with docking station and now (probably a year later) the camera wont focus. When i turn it on everything works fine but the view is all "squiggly" for lack of a better term. I wouldnt mind so much if it was just the lcd, but the pictures come out the same way. If anyone could point me in the right direction I would be very thankful.
  • HP Master
  • 5,527 Answers
Sounds as if there is damage to either the lens or the lens focusing mechanism.
Posted on Sep 21, 2017
bmwrider
  • 215 Answers
SOURCE: LCD screen displays menu items but will not display picture capture & won't take pictures
A very common problem with many Digital cameras. It sounds as if you are suffering from either a CCD problem or a video board problem. Impossible to tell without it being on the bench to check. You could dismantle it and check there's nothing adrift such as flat ribbon cables in their sockets or loose plugs and sockets between the printed circuit boards. Watch out for the flash unit it can give you a nasty shock if it's charged. Most cameras seem to built to last as long as the warranty and then die. This keeps you coming back for more. At least you were lucky to get 2 years out of yours before it passed on.
Posted on Jul 12, 2006
SOURCE: HP R927 Camera
I had this problem with my camera after a year. Scratching the battery contact terminal inside the camera fixed it.
Posted on Nov 11, 2007
SOURCE: My Camera Wont Turn On To Take Pictures
i had this problem also. i tried reinstalling the program on my computer, buying new batteries and charging them with an external charger. nothing seemed to work. i was convinced the problem lay with the camera.
i had taken the camera at one point to a very cold and dusty environment (a glacier). the lens cap started getting stuck after that, and it would occasionally not send out the lenses. i had dismantled it to clean it, which kind of worked.
this time, i was certain it was something to do with the recharging system in the camera. however when i opened it up i noticed 2 things...
a) one of the 4 base screws that hold the battery cover on, had been put back in the wrong place... these screws are about a millimeter longer than the other black screws, and in the wrong place could have been shorting it out.
b) the front and back covers are grounded by a strip of copper on the side opposite the strap retainer. these were crushed and could have been also grounding something out. i straightened the strips out and put everything back together, testing the on/off button after every couple of screws.
i am happy to say that i got mine back working again. i put my experience down to inexperience and the difficulty of doing a field repair the first time. tools required: magnifying glass, bright light, and a very fine philips screw driver (1mm).
p.s.: the lens caps still sticks partially closed, so i never did fix that problem. LOL!
Posted on Jan 25, 2008
SOURCE: LCD viewer screen blacked out
Really? Your lcd screen might be damaged! take it to someone who can tell if a pixel is damaged or not.
Posted on Dec 24, 2008
SOURCE: LCD Display Blank
When the camera is turned on, the LCD diaplay screen is blank (dark
Posted on Feb 06, 2009
Why wont my HP photosmart R967 turn on battery is new and docking station is fine but it will turn on if connected to docking station
It is likely the battery is not making contact properly or is not getting fully charged.
Check the instructions on battery connection on page 9 and confirm the lights are blinking correctly to show battery is charging.
http://h10032.www1.hp.com/ctg/Manual/c00717663.pdf
Aug 03, 2014 | HP Photosmart R967 10MP Digital Camera,...
Casio exilim lens retracts wen u press to take pic
The battery probably needs charging. The camera will automatically shut down if the battery is going flat.
With the Exilim you need to make sure that you don't overcharge the battery by leaving it permanently docked in it's little docking station - this can damage the battery. There is an LED on the docking station which shows the status of the battery. Red is charging, green is fully charged - take it off the docking station.
Dec 11, 2008 | Casio Exilim EX-Z77 Digital Camera
Camera won't charge
Hi!
It's a problem with the battery. It already reached it's life cycle. I had the same problem with my 15 month old casio camera a year ago - flashing red light on docking station. I even tried borrowing a docking station/charger to see if something else is wrong with it.
The only solution for this is to have the battery replace.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Charging flash stays on and i cant take a picture what can i do?
help me solve this problem. - my camera stays "charging flash" and cannot take pictures
Sep 30, 2008 | HP Photosmart 735 Digital Camera
It will not power on.
Hi Ken if you bought your 735 new it has a cradle a (docking station)if you had tried the batteries and still not powering up you need to eliminate other possibilitys try powering up the camera on the docking station make sure power cord is on if the cam fires up that way then this will no doubt a camera shop fix,I repair on the side would be interested in trying the repair to at least give you some more closure on deciding if the cost of the repair is worth considering these are and been outdated quite sometime ago and a repair could supercede the price of the camera when purchased if you want e-mail me and i could try a few walk threws with you and see if we can cure it.
thanks,steve
Sep 01, 2008 | HP Photosmart 735 Digital Camera
Hp 945 frosen with red light on
I posted on July 16 with this flashing problem and played around and got mine working again.
Originally I would charge through the docking port. What I did was pull the charged rechargable batteries out of the camera and took the charging cable from the docking station and pluged it directly into the port on the side of the camera. The camera started working again. Then while the charging cable was pluged into the camera, I reinstalled the rechargable batteries. After installing the batteries I unpluged the charging cable and the camera still works. I have shot and downloaded from the camera pictures with no more problems. Use the docking for downloading pictures and the side port on the camera for recharging the batteries.
I do not know if this has anything to do with the original problem but I did not have any problems with this camera until I placed it on the docking station with non-rechargible batteries.
Hope this helps.
Jul 02, 2008 | HP Photosmart 945 Digital Camera
Continuous flash charge
Try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 23, 2008 | HP Photosmart 735 Digital Camera
Frozen Open
I hate to post without offering a solution and while checking for a possible error code list for the camera, I ran across this:
http://www.digitalcamera-hq.com/digital-cameras/hp-photosmart-735_product-reviews.html?reviewsPage=1
HP once made great test instruments under that name but the average quality of stuff related to computers or digital technology has been mixed at best and often, outright atrocious.
I don't service HP computers at all any more; along with their poor quality, another item that once was among the best, service support has also plummeted.
Apr 10, 2008 | HP Photosmart 735 Digital Camera
HP Photosmart 735 "unsupported image file"
You might want to try a different memory card.
Jan 21, 2007 | HP Photosmart 735 Digital Camera
HP Photosmart 735 Digital Camera Logo
37 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
