Question about Your One Source Homeline Load Center, 200 Amp
Do i need to bond the panel frame to a grounded bus ?
Homeline load center 200a indoor
    Sergeant:
  • 359 Answers
Yes but to frame ground only not the neutral buss as this is to stay isolated
Posted on Dec 09, 2008
Are factory installed breakers already bonded
Get a letter from the manufacturer saying that the panel assembly and components meet all applicable National, State and Local codes. The inspector is an xss.
Nov 21, 2013 | Your One Source Homeline Load Center, 200...
I have a 200 amp homeline loadcenter with factory installed breaker the code inspector is telling me that it has to have a bonding screw however there is no tapped hole for a bonding screw. I read that...
For the neutral buss bar, a bonding screw goes through the buss bar into the box. Same for the ground buss bar. Usually, neutral does not meet ground until the meter, so there may only be a bonding screw for the ground buss bar. Look carefully, check with electricians.
I have a 200 amp homeline loadcenter with a factory installed breaker and the code inspector is telling me we need a bonding screw however there is no tapped hole for a bonding screw
I checked my code sheet, and only the ground bus is to be bonded to the box. The box comes with a screw that will bond the bus to the box through a bus mounting hole, the threaded hole is down there, behind the bus. The neutral does not get bonded to the box.
I recently had new service installed. 200 amp load center at the top of my stairs, and a QOM2E2200NRB 200 amp enclosed breaker next to the meter socket. Idiot electrician bonded the neutral in the load...
Problem is not clear.
You have 200 Amp cut off by meter, with 3 wires from meter box:
2 Hot wires and a ground.
http://waterheatertimer.org/See-inside-main-breaker-box.html
You have 200 amp service panel.
Does the ground wire enter service panel from cut off box?
Feb 24, 2013 | Electrical Supplies
I am taking electricity from my home to my garage. I have a Q06-12L100s load center in the garage and want to know how to connect the wiresl. The ground is obvious. The white wire is connected to the big...
Here's a picture of a messy amateur installation:
Look closely and find the power feeder conductors entering the panel on the bottom. The white rises up to the right and terminates in the "neutral" bus lug on the top right. The black also rises up to the right and terminates in the left "line" bus lug on the left. The red wire rises up to the left and terminates in the "line" bus lug on the right - just below the neutral lug. Finally, the ground rises left and terminates in a separate ground bar that is secured directly to the back of the upper left side of the panel box in pre-tapped holes for this purpose.
Since you are supplying this panel from your home's panel, you MUST keep the neutral and ground feeders separated in this panel (even though they will both probably originate from the neutral bar in your home's service panel). You must NOT install the long "bond" screw through the neutral bar in to the panel box. If the long bond screw is already installed, you must REMOVE it (usually this screw it shipped loose in a bag with a tag on it).
When the picture was taken, the flash reflected back making the right side of the neutral bar difficult to see - so I can't determine if the screw is installed there or not. When connecting circuits to this panel, the hot wires will of course go to the circuit breaker terminals, but the neutral and ground wires must not be mixed. The ground wires (and ONLY the ground wires) must terminate in the ground bar. The neutral wires (and ONLY the neutral wires) must terminate in the neutral bus bar. The person that wired this panel has mixed them. This would be a dangerous situation if the the long bond screw mentioned above is installed in the neutral bar to bond it to the panel box.
I hope this helps and good luck. Please rate my reply. Thanks.
Jun 18, 2011 | Square D Co. QO612L100S Main Lug Load...
I need a 15A GFI circuit breaker that fits into a Square D Homeline Load Center - it is not available locally - what other manufacturer's 15A GFI circuit breaker fits into a Square D Homeline Load Center?
That number in the heading is not correct. While you might find a breaker that "fits" your panel there is no other brand that is listed to work with your panel The correct number would be
HOM115GFICP If you can't find it locally, there are many locations you can order one from online. I don't know where you are locatged, but an electrical supply house or even homedepot should have one.
Nov 21, 2010 | Square D Circuit Breaker Load Center...
I have a 30space 200A load center from Homeline, and I have a tandem 20A breaker with the model HOMT2020. It will not lock in. the buss clip fits but the plastic case where the cut is to recieve the bus...
There are several variations even within brands. When in doubt, remove an existing breaker and take it to the hardware store with you to match the format. That way you get the right one in one trip.
Regards, Farmerbear
Sep 10, 2010 | Your One Source Square D #HOME250SPA 50A...
I am trying to install a 100 amp breaker into a Homeline 200 amp load center. Breaker flips every time main breaker is turned on.
I'm assuming since it's a Homeline panel you're using a HOM2100 breaker. If it stripping then you must have a short circuit in your 100A circuit, or the breaker is defective. Disconnect your load from the breaker, and turn main on. Be sure you have the correct load conductors connected to the breakers. Typically red and black on the breaker, white on neutral bar. Bare to ground bar
Sep 06, 2010 | Your One Source Homeline Load Center, 200...
Can i replace the main (100 amp) is a sq d QOC20u100F panel with a 200 amp main--i will up grade meter socket and entrance cable to 200 amps cwalker
First the part number QOC20U100F is a flush mount panel cover. The panel you have is most likely a :QO116M100. No you cannot replace the breaker as the bus in the panel is only rated for 100A. In addition I believe this is a 20CKT panel. If you're gonig to a 200A service you'd probably want more spaces than that. Home Depot and Lowes both carry 200A panels with starter set of breakers at reasonable price. The QO panels are a bit better than the Homeline
Here is a link to manual for their panels. :
http://static.schneider-electric.us/assets/DIGEST/load-centers.pdf
Aug 21, 2010 | Your One Source 100 Amp Main Lug Load...
What gauge wire do I need to lead into the BR816L125R load center? it is going to the feed through lugs off my 200 amp service breaker.
Hi .. If the load center is next to the main panel you can use #2 copper or #1aught aluminum. You need to use 4 wires .. two hot, neutral, and ground. And in your load center you will need a 125amp main breaker and you will need to keep the neutral bus separate from the box, do not use the bonding screw. You will then need to install a ground bar to the back of the box for the ground wires connection.
any thoughts, questions.?
Jun 19, 2010 | Cutler Hammer Cutler-Hammer...
Your One Source Homeline Load Center, 200 Amp Logo
231 people viewed this question
Top Your One Source Electrical Supplies Experts
Steve
Lisa
Lisa
ray gallant
Are you a Your One Source Electrical Supply Expert? Answer questions, earn points and help others
