Question about Samsung LN-T4665F 46 in. LCD Television
My LCD TV has a red background instead of black. Everything is red, even when I disconnect all cables. It used to be black, and now, whatever source I use (component, composite, whatever), the images are all red.
    Champion:
  • 225 Answers
Backlight bulbs turn red when they go bad. They are hard to replace, and require soldering. They contain mercury vapor, so I would be careful not to break them. Bulbs cost about 20 each usually. Could be 2-4 bulbs to replace. It is a pretty difficult repair, good luck.
Posted on Dec 06, 2008
Protron usa
If it's completely black, then a ribbon or cable internally is disconnected or the panel is bad or the light source (LED or whatever) is burnt out and will need a new one. Chances are it's broken to where you should buy a new TV rather than repair
Apr 09, 2014 | Televison & Video
REd background instead of black
It is low voltage in the screen driver board, probably a bad capacitor in the screen driver board or perhaps in the main power supply. The only way to tell would be to look at a schematic and measure the voltage and check the voltage source on the power supply board. If the voltage was low, replacing the board should fix your problem. If the voltage was normal at the power supply, then the screen driver board would need to be replaced. Good Luck
Dec 06, 2007 | Televison & Video
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
I have a 9-month old Sanyo LCD 32K40L colored TV. The TV reception just became black and white. This is the first time this happened.
How is the set hooked up? Check the cables on the back of the set. If you are hooked up with component cables (red, blue, and green) make sure the cables are good and that they're not disconnected from the set or cable box or whatever. Plugging in the green cable only will give you black and white. If you are using the tuner (use the TV remote to change channels) then you have a weird problem which may be a bad tuner or maybe a bad main board if the input signal checks ok. Hope this helps.
Apr 29, 2011 | Sanyo Televison & Video
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Blinking red and green squares with blue fuzzy bars in the back
Before thinking of TV problem, you should play a DVD first and see how it goes. TV problem only happens when all sources were affected. If you have the same problem for all sources, open the cover, disconnect LVDS cable and re-connect it; then try to tap or shake gently the LVDS cable and see if the picture changes. If yes, replace LVDS cable. If not, then measure the power on supplies from main board to power supply board, see this 5 VDC is stable or not. If it works fine, the problem may come from T-con board or some case from defective panel.
Aug 17, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
No picture but can hear volume
Try unplugging the TV cable from the mains and leave it off for a few hours. The longer you leave it disconnected from the mains ( i recommend overnight) the better the chance it will reset the TV.
When you switch the TV on, try pressing the SOURCE button until you get a picture from the cable/sat box or whatever connected to the TV.
If this fails you may have a problem with the power circuit board. This will cost approx £150 for parts and labour from you local TV repair man.
Good Luck
Jul 27, 2009 | Samsung LN-R408D 40 in. LCD HDTV
I have issues with my unit. Sync problems
Are you sure it's the TV and not the video source ? Have you tried other video sources ? You can also try to switch over to component cable. The red/green/blue colored cable. You only need HDMI for blu-ray to get the 1080p. If your TV is only 1080i then you don't even need to use HDMI. Also, some sources actually look better with a component cable compared to HDMI. Give it shot.
Mar 14, 2009 | Samsung LN52A550 LCD TV
Lcd, display with red instead of black
Check the Video cable and try moving the it around and see if the color will come back normal. This kind of problem can be cause by faulty cables.
Nov 27, 2008 | Computers & Internet
Samsung LN-T4665F 46 in. LCD Television Logo
160 people viewed this question
Henry  Thomas
Henry Thomas
