Question about HP OfficeJet G85 All-In-One InkJet Printer
The screen on FeskJet g85 says that cartrdge alignment has failed
It shows it numerous times. Won't let me to even accept a fax coming in.
    Scholar:
  • 69 Answers
Here is the link below which helps you in resolving the issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=60399
Click on the link above to open web page and follow all the steps given in document.
Thank you.
Posted on Dec 06, 2008
  • Robun Nov 29, 2010
    nothing i do to the G85 wil align the print Carts. the only color that will print is the magenta.
SIR PRINTER SCREEN SHOWING DOOR OPNE, CLEAR
sir printer screen showing door open, clear cartrdge jam and then press enter
Jan 18, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
My office jet G85 has the message "remove and check color
Check and make sure you drivers are up to date. You may need to un-install the printer software and remove the printer in the control panel. Then reboot the computer,install the software(check and see if there is updated software if so download it).Then install the software and usually gives you instructions on when to connect the printer and drivers should be installed by software. Also make sure that when you use the print screen that you have the default printer selected and that the office jet is the default printer. It may be set to print to Microsoft one note for example.
Sep 05, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
How can i fix my Alignment
for Alignment you have to use ur stick to touch the center of the cross mark appears on the screen so that the alignment problem will solve
Sep 03, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
My HP DeskJet g85 says "cartridge alignment has failed"
Here is the weblink which helps you in resolving cartridge alignment failure issue:
Click on the link above and follow all the steps give in web document.
Thank you.
Dec 06, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
OfficeJet G85xi cartirdges will not align
Could be one of two things....
1 - you may have bad cartridges (usually the color)...when the machine does an alignment it looks for specific marks on the paper...ie..green check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...first replace color cartridge with a HP Brand cartridge
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Inkworks
866-381-0541
Aug 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Alignment problems
Here's the deal with the cartridge alignment page....the machine will spit out a series of black lines mixed with yellow ink and at the beginning of each of these lines is a "Green" check mark. The carriage moves back and forth over these lines and green check marks and reads them by use of what is called a "spot sensor" that resides on the right side of the carriage assembly. This is usually noticed by the blue ray of light that shines out of it. So if you are getting an alignment failure one of two things is happening....1)You've have got a bad cartridge (usually the color) and it is not laying down the right colors, specifically the green check mark or 2)You've got a bad spot sensor...even though it may still be shining the blue light, the sensor board can't process the information. Its an easy fix either way.
Inkworks
Apr 25, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP G85 auto-answer
yeppers...same thing happens to mine. So, I simply set it to receive faxes manually now.
Jan 18, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
90 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
