Question about Dell W4200 42 in. HD-Ready Plasma Television
Using an over the air antenna I get all channels but one.
I have a Dell 4200 TV with a digital tuner.  Using an over the air antenna I get all channels but one, our local CBS affiliate.  It is on digital channel 50.  I get other stations that are on the same tower here in town.  Strangely, I have had times where the CBS channel will come in with a strong signal, but if I change the channel, it never comes back, even if I manually search for the channel.  Dell replaced the TV, but that did not solve the problem.  We get analog reception of this channel just fine.  With digital only TV coming, I am not sure what to do.
  • 1 more comment
  • jbhagel Jan 28, 2009
    I have the exact same problem. Local CBS digital will not tune. It's broadcast over RF channel 32. It used to come in when the TV was brand new, but has since stopped working. Our other TV shows the signal strength at 89%+, so I know our reception is good. I've got the Dell in the service shop now, but the technician is having problems finding replacement parts for it.
  • Anonymous Mar 31, 2009
    I have the same problem too, in my case ABC, but I can receive clear signals from a weaker station that's over 50 miles away, but not the local station that up to one point, was my strongest and clearest signal. It just stopped tuning it in one day, though all the other TVs in the house get the signal fine.
  • jbhagel May 11, 2010
    Unfortunately in my case it's not the antenna. The family room TV gets the digital CBS station just fine, and is wired to the same antenna as the Dell plasma TV in the entertainment room.
    The local TV repairman could not find a new tuner replacement for the Dell. He recommended an external tuner box. For a HD ATSC tuner, that's about $180+ not including an HDMI cable. It's not the solution I was looking for, but it looks like the only HD option now.
    New Friend:
  • 90 Answers
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
Posted on Jan 31, 2009
Using a digital antenna to channel scan for broadcasted channels
It is no different that channel scanning for cable or analog over-the-air channels. You simply ensure that you have selected the digital tuner of the set prior to scanning. Some older flat panel sets do not have integrated digital tuners. A digital antenna alone will not allow these sets to receive digital broadcast channels. A converter box is needed to convert the digital broadcast signals to analog for the tuner in the set. Also, sets that do not have digital tuners may not support the resolution rate of digital TV broadcasts. Most digital HD broadcasts are 720p and a few are 1080p.
Jul 28, 2016 | Televison & Video
No picture or sound
You need a antenna HD for air signals. I hope this helps. leave feedback and thank you
Jul 11, 2016 | Televison & Video
How to install indoor digital tv antenna to a lcd tv & pickup digi channels
First, the LCD TV has to have a digital tuner in it. Older ones may not. If it does, then you attach the antenna connector to the TV connection that is marked TV IN or CABLE. Then, in the TV's menu, you would need to ensure that the digital tuner is selected. Once that is done, then, still in the menu, perform an "ON AIR" channel scan to find and lock in whatever digital channels that the antenna can detect.
Aug 05, 2015 | Electronics - Others
Do I need a digital converter box & antenna to get
It really depends upon your TV. If your TV is newer and has an ATSC tuner in it, then no - you'll just need the antenna. However, if your TV is older and doesn't have an ATSC tuner, you'll need an external tuner, what you're calling digital convertor, and an antenna to get the local channels. Use Google or another search engine to find the specifications for your TV to see if it has an ATSC tuner. Or, connect an antenna to your TV, run the channel scan (off-air antenna mode) to see if you get any local channels. If you don't, you'll need the external tuner.
Sep 29, 2014 | Audio Players & Recorders
Can I hook tr 2920 theather research speakers to a stereo
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
How to make TV scan cable channels
the tv scan function is for antenna users. If youre using a cable/dish box, any kind of digital tuner than you do not need to scan for channels. just select your digital tuner
Feb 04, 2012 | Sharp LC-19SK24U TV
Does this model have a digital tuner or do I need to have a box to watch televison over the air?
Yes this tv dose have a digital tuner inside of it,all flats LCD and Plasma tvs are Digital tvs they all can get free DTV air broadcasting tv channels.All digital flats LCD and Plasma tvs are DTV set u just require a very good like a roof Antenna or a newly Digital design portable Antenna connected the tv incomming air broastcasting signal cable back of to the flats screen tvs at the axail input call ANT.Then go into the tv menu.Goto setup go down pick AIR than press the enter button for scanning for free DTV air broadcasting channels.After the tv finish scanning for channels than the tv will let ur tv to get all the free DTV broadcasting channels.
Sep 29, 2011 | Olevia LT32HVE 32 in. LCD Television
How to get the dell 4200 ed to pick up digital channels
there are 2 coaxial inputs on the back of your tv. plug the antenna into the digital coax. with your remote, do a fac reset: menu, setup, fac reset, all settings, passcode 3355. after the reset, hit input, select digital tv. perfprm a chan scan: menu, setup, channel scan, antenna. this should solve the problem.
Feb 09, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Dell W4200 42 in. HD-Ready Plasma Television Logo
701 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
