Question about HP Computers & Internet
I turned on my computer two days ago and the screen was so skewed on the horizontal that I was unable to view the clock on the tool bar and the start program button at the same time. I have tried to adjust this by using the horizontal and vertical buttons. Moving the screen with the vertical button is not a problem, it works. Unfortunately nothing seems to happen when I use the horizontal button. The picture remains the same. I am wondering if the monotor is on its last legs?
    Novelist:
    Scholar:
  • 85 Answers
Most likely the refresh rate in your display settings is set to high
lust right click on an empty spot on your desktop and click "properties" from the drop down menu or go to control panel / display and once you are in the display settings window click the "settings" tab on top then click "advanced" then "monitor" and make sure it is set to "60hz" (some monitors go higher but 60 is safe for just about all of them then click apply and see if the problem goes away
If it is already set to "60hz" then there might be a problem with your monitor itself
or it could be a monitor setting like "trapezoid" setting but not many monitors have this setting and it would be rare for it to get accidentally changed but just in case you could always try to go into the monitor settings menu and look for "reset" or "restore" function and if your able to reset it and it still has the same problem then it is probably your monitor is giving out and time to replace it
NOTE: the above solution is based on the assumption that you are using Windows XP with a CRT type monitor (not flat panel or LCD)
Posted on Dec 06, 2008
Monitor w2261vt
Make sure that your software, that you view your pictures with, falls into the 'box format' of 640x480, 1024x768, 1280x1024, etc. Background pictures are typically streched to fit the wider screens. You can change that by right clicking on your desktop.. in XP it is the 2nd tab, on the right side, you can choose stretch or ? Some will give you black bars but no skewing. Then you can adjust your monitor's resolution downward to enlarge your pictures, or leave it at a higher resolution if you don't mind the borders. -DellTech1
Oct 31, 2013 | LG Computers & Internet
I got my computer two days ago and the clock is not right. How can I reset it?
Click on the time at the bottom right of your screen. When you get the expanded view, click on the hours, minutes of the digital readout to change each.
Jan 12, 2013 | Car Audio & Video
Talktalk toolbar will only disable - I want to enable
Which internet browser are you running you might have to update it
or
Internet Explorer includes a toolbar that allows you to browser the Internet or perform different functions in your browser.
The toolbar allows you to navigate web pages, add browser add-ons such as pop-up blockers, save and print pages and more.
If you are unable to see the toolbar or components you want to use, enable them quickly using these simple steps and guidelines.
Click the Windows "Start" menu and click "Internet Explorer" to launch your web browser.
Click the "Tools" menu located on the top and click "Menu bar" if you want to view the menu bar.
Alternatively, press the "Alt" key to display the File menu.
Click the "View" menu, select "Tool bars" and click the "Menu bar" tool you want to display the menu bar.
If you want to display a different toolbar, select it
hope this helps
Oct 18, 2012 | Computers & Internet
Compaq mv540 monitor suddenly can't adjust screen features
Please somebody give a solution as same is experienced by me tooo.
Jan 22, 2010 | Compaq MV 540 15" CRT Monitor
The screen is stretched there is nothing distorted
What kind of monitor? They can all be adjusted for width and height by using the buttons along the bottom of the screen. Often it can be confusing and a bit of a pain but look under the monitor menu for 2 sets of icons that look like 2 boxes on top of each other both horizontal and vertical. That is how you adjust it.
May 29, 2009 | Acer AL2216WBD LCD Monitor
Color and other problems with SyncMaster 910 MP monitor
Go to => http://www.samsung.com/us/
Type 910mp in the search dialog box.
Select Download English Manual. It's about 20mb.
The manual has instructions for setup including adjusting your monitor. There is even a section troubleshooting and a self-test. Good Luck.
Dec 12, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Mitsubishi big screen won't stay on!
Its very possible you have a failing resistor r2200
Nov 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
I am unable to open Norton Security Centre and it has disappeared from my tool bar
try : START > SETTINGS > classic mode > there should be a symantec icon in the settings screen , or reiinstall the product (not by any change set the icons with the clock to hide ? (rightclick on the taskbar , go to properties > system tab > check if there are un activated icons
Apr 25, 2008 | Computers & Internet
Picture deterioration
Your whole problem my freind is dryed up capacitors. You should go, if you have the technical ability to replace these capacitors, to http://servicemanuals.net, download the schematic diagram, and start replacing the waveshaper capacitors in the vertical drive circuit.
Sep 23, 2006 | Sony KV-35V35 TV
Computers & Internet Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
