Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag sde3606ayw make loud screeching noise
When running my dryer is very loud. It drys just fine. Also it makes the same noise if I open the door and manually spin the drum with my hand. What could this be and how might i fix it? Thanks for your time.
  • junyor Jan 11, 2009
    I had the same problem except my belt came off the pulley and now i have no idea what to do....
You Need to replace the drum Rollers. They cost around 10.00 Each online, 20.00 Each at your Dealer. Please Dont try to Put Oil on The Roller Shaft. It will come off and make its Way To Your Clothing. Martin Appliance Sells Specific Oil for the shaft for around 8.00. Thanks Sean
Posted on May 16, 2010
Dryer continues to run when I open the dryer door.
The door lock is more than just a latch; it is an electrical interlock. From your description it is likely that the interlock has failed
Jun 02, 2013 | Maytag Neptune MCE8000AY Electric Dryer
I have a GE dryer that make a very loud screeching noise when turned on. The heavier the load, the louder the noise. The noise gets quieter as the load drys and the dryer barely makes it when turned on...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 16, 2011 | Dryers
Open front panel on maytag Sde3606ayw?
there are 2 screws near the floor below the door that will let you access the lower front area,then you can remove the door assy and finally the top cover if necessary
Apr 19, 2010 | Dryers
My maytag dryer was making a loud screeching noise and then stopped spinning or heating
heatman101
dgsghs
Feb 10, 2010 | Maytag LSG7806A Front Load Stacked Washer...
The dryer makes a loud noise when running. It still works and drys. Its a loud screeching sound. Do you think the belt needs to be replaced?
Could be the one of the 4 drum rollers, Idler pulley or belt.
I usually replace them all at once for long term reliability.
Jan 08, 2010 | LG DLE3777 Electric Dryer
Very Loud Dryer
squeeling hi pitch is usually the drum support roller above the heater. if you take the machine apart and turn all moving parts by hand you should be able to find the problem...if its a rumbling noise then it may be the blower wheel. UNPLUG FIRST..good luck :)
Jun 13, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag LDG9334AAE Gas dryer making popping noise from vent
clean clean clean everything, dont let it go to much longer or you will have a fire, and dont ignore this or you regret it... then tell me if it makes the noise
May 07, 2009 | Maytag Dryers
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
Dryer screeching when on
likely has a slipping belt , it will smoke before too long,
unless something got between the drum and door and is scratching .
Mar 22, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
797 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
