Question about Dishwashers
I have a brand new Miele dishwasher which has worked grate since it was installed 2 weeks ago. It keeps shutting itself off & indicates an F13 fault. I looked in the manual, see that water is going in fine & pressure is good. It then says to clean water intake filter. How do I get to that ? I don't have a user maintenance manual. I'm on city water & doubt that the filter is clogged but My wife will kill me if I don't get it fixed today. Can anyone help. Glenn
On my Miele 1220 dishwasher, the inlet filter is inside the inlet hose connector, where it screws onto the water supply. To clean it:
1. Turn off the stopcock. 2. Unscrew the inlet hose. 3. Remove the black rubber seal gently with a screwdriver. 4. Use pliers to remove the inlet filter. 5. Clean the filter under running water. 6. Replace the filter and seal. 7. Reconnect the inlet hose to the water supply, making sure the screw does not thread. 8. Turn on the stopcock slowly to check for any leaks.
Posted on Jan 12, 2010
My 73in Sony TV shuts off by itself every 10-15 mins and there's blinking. Then it turns back on and repeats. About a week ago I installed a brand new bulb. Could it be the bulb assembly or what? Please...
that sounds like the control board is overheating and the graphic chip is getting fault and keeps shutting down.Or the power supply as a bad capacitor, and that can do the same thing .
Thanks
Nov 22, 2013 | Televison & Video
Optima G2430 Miele dishwasher with F13 error
F13 Indicates that you have a water intake fault. The machine is not receiving the the proper amount of water quantity. You could turn off the water supply and disconnect the water inlet hose. There is a filter inside, to remove the filter you have to take out the seal and then you could use a pair of needle nose pliers to take out the filter basket. If the filter is clean you and your water supply is good, you have a problem with your flow meter not registering pulses when the water is taken in.
Feb 05, 2012 | Miele 24 in. Incognito G843SCVi Built-In...
When attempting to start dishwasher load the signal F 70 come up and it wont work. Purchased 2nd Jan 2008.
F70, waterproof system activated. this means you have water in the bottom pan of the dishwasher. your miele shuts itself off and runs the drain pump continuously any time water leaking is detected. you can pull out the black plastic toe kick under the door. there is a cover panel in the center held on with two t20 screws. you can dry up the water and try to run a cycle. if it works ok, cut back on your detergent by 1/2. if it leaks again, you should probably request service from miele. if you want to try to repair it yourself, let me know and I will help you troubleshoot it further.
Nov 17, 2010 | Miele Dishwashers
F14 problem with miele dishwasher model G2270SCVI WOULD be grateful for your assistance asap as nothing in manual explains what to do. many thanks
Hi F14 is when the pump pressure switch does not operate. This can be caused by several things. Circulation motor blocked or defective. Insufficient quantity of water in appliance.Most commonly it is debris in circulation pump.This will require motor to be removed and cleaned.appliance will have to be un-installed
Jun 17, 2010 | Miele Premier-Plus Built-in Dishwasher
F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday: 8:00 am - 8:00 pm EST Saturday-Sunday: Closed
http://www.mieleusa.com/usa/contact/contact_miele.asp?page=1
Apr 20, 2010 | Miele Premier-Plus Built-in Dishwasher
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Dishwasher not filling
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 21, 2009 | Miele 24 in. G646SC Plus Free-Standing...
F 13 problem indicated on miele g2420 optima dishwasher
Its on the end of the water intake line - ussually under the sink - connected to the hot water line.
Dec 06, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
Phone will not stay on...?
Looks like the accu is dead, or just defect...
Within 2 weeks...
Just contact the shop for warranty service.
Mar 27, 2008 | Cell Phones
Dishwashers Logo
1,444 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
