Question about Plumbing
Ebara pump i have an issue with the AA when i turn them on they start running for bit then they slow down then they go up again and then the slow down again. I would like to know the reason why this is happening.
  • Joseph Lukas May 11, 2010
    WWhat is the Model number, the flud you are pumping and the application. Also the temperature of the fluid
  • 99 Answers
SOURCE: stalling at lights
Did you replace the fuel pump because of the problem? Or did the problem start after replacing the fuel pump? If it started happening after you replaced the fuel pump, take it back to the place you had it repaired (or if you did it yourself take a look) and ask them if there may be a loose connection or a leak that might allow air into the fuel system. Also, replacing the fuel filter might fix the problem as well.
Posted on Mar 01, 2009
  • 7 Answers
SOURCE: 1992 Lexus LS400- slowing down on interstate for
Had the same problem with mine...replaced the fuel pump...worked like a charm...
Posted on Apr 17, 2009
boysor2933
  • 293 Answers
SOURCE: Ebara dominator 1hp automatic pump 110v blows circuit
Try to relocate the position of the pump where it would be protected from water splashes. The pump motor casing might not be designed for outdoor use or not desirable for water splashes. You may also replace your pump with units designed for this purpose (pump with motor casing rating of IP 65 or IP 55).
Posted on Jun 11, 2009
  • 832 Answers
SOURCE: pump repair
You can begin by typing at the search engine of the internet: http//pumpcatalogue.com/
Posted on Oct 29, 2009
rajeshpait
  • 542 Answers
SOURCE: shut downs suddenly
This may due to faulty power supply. Check the output of the power supply, change or repair the same will solve your problem.
Posted on Dec 08, 2009
A friend of mine gave me a zr series ,625cdv homelite weed eater and I can't figure out how to adjust the carb. Bought a new primer bulb it crank and run for a little bit but I have to idle it high
Screw in the HIGH and LOW needle valves. Then turn each one out 1 full turn, That should be a good starting point.
After engine is running Run engine at Full throttle. Loosen HIGH screw until the engines RPM slows a bit. When that happens Turn screw back in until it revs high and then just starts to slow again. You do not want the engine to run at it's highest RPM or it's not getting enough Lubrication It need to run Rich, that's why you screw the screw in a bit after the engine has reached it's highest RPM. Let it idle down . Then Accelerate hard, if it hesitates, loosen or tighten the LOW until it accelerates quickly with no hesitation.
May 30, 2017 | Homelite Garden
My car wont start :(
Your car won't start just follow 1 on your car if key can't turn on is the key holder spoil 2. take the motor out to check and later fix it it make me spoil too 3 call your car workshop company.
Jul 06, 2014 | 1991 Toyota Corolla
How to open ebara best4 sump pump to check electrical connections and capacitor
I would recommend that you either replace it or get a professional to rebuild it. If it is not done properly it will become a shock hazzard.
Aug 24, 2013 | Ebara Plumbing
The Ebara EPPD 3MS1 pump will trip the GFI breaker on the outlet
Will the Gound fault socket (outlet) support the current rating of the pump
is the outlet wired correctly where the return wire is in the correct spot and the high and ground is correct not switched around?
Does the pump run in a standard outlet?
Test it with a heavy duty extention cord if no standard outlet socket is nearby?
Is the pump shaft dragging putting an un necessary load on the motor?
Aug 02, 2009 | Ebara EPPD-3MS1 PRO-DRAINER Manual Sump...
Jun 06, 2009 | Plumbing
Pump repair
Mar 17, 2009 | Plumbing
Stalling at lights
Feb 14, 2009 | 1994 Pontiac Grand Am
Initially starts fine, runs fine, then stalls at the first stop.
This is a fuel pump issue. i would replace it and the lines as well.also, a minor tune up wouldn't hurt as well. wires plugs distributor cap points etc...
Feb 11, 2009 | 1992 Dodge Dakota
Fuel pump, fuel filter???
Had the same problem. Just changed the fuel pump today and now working great. Good Luck!!!!!
Jul 06, 2008 | 1993 Dodge Grand Caravan
Plumbing Logo
98 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
