Question about Microwave Ovens
Beeper is too loud
Our WES1384SMSS's beeper is so loud that you can hear it clearly throughout the house - not a good thing when family members are getting up in the morning at different times. I've wrapped some 1/2" thick hot water pipe insulation material around the transducer but it doesn't help much.
I've thought of removing the transducer, but I don't want to do away with the beeper completely - just quiet it down. Besides, I don't know how it might affect performance otherwise.
A variable volume would be perfect, but there is no access to a lead I could tap in order to wire in a volume pot.
Any suggestions? BTW, this model is sold only at WalMart, and info is lacking on the internet. But a GE JES1384SF looks similar, although it is 1100 watts compared to our 1000 watts.
Thanks
Dan at dclarke(at)gefa.ga.gov
  • Microwave Ovens Master
  • 9,098 Answers
If you can take good photos of both sides of the board, I can probably show you what resistor to remove.
You could replace that with a trimmer potentiometer I can specify for your from Radio Shack.
Feel free to contact me directly if you'd like.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 08, 2008
My TMV151FB beeper stopped working. Is it worthwhile fixing it?
if ever thing else works but the beeper I would not worry about that
May 24, 2015 | Tappan Microwave Ovens
Magic Chef MCD1311ST: Our microwave oven no longer beeps. Is there a way to fix the problem?
I assume you are certain it isn't your hearing going bad - sometimes the high-pitched tones of beepers become inaudible without properly functioning hearing aids, or the ability to hear certain tones disappears altogether. This is easily checked by asking someone with known good hearing if the beeper is working. Hearing problems can occur at any age, so don't dismiss this too quickly.
If everything else works normally, it is either the beeper (usually a piezoelectric disc on the controller board or attached to the board with wires, but sometimes a small speaker) or a fault in the controller board's beeper circuit. The first thing I'd do is check the disk and any wires for cracked or loose connections. (CAUTION: unplug the oven before removing the cover.) It's usually located on or near the controller board behind the key panel. Generally, piezoelectric discs are about 1/2" to 2" in diameter, have a brass rim with a silver plated ceramic center, and may be enclosed in a drum-shaped black plastic housing with a hole in the center to let the sound out.
If the disk is connected to the controller with wires and a removable connector, unplug the connector, clean the pins and test it. Piezoelectric audio devices use very little current, but a dirty or oxidized connection will still keep them from working. It is possible that the disk itself has mechanical (spring) contacts, and the silver electrode plating at the contact is tarnished. In that case, gently clean the silver with a soft white pencil eraser. Do not over-polish; the silver film is very thin.
Is is possible, but difficult, to repair a cracked solder connection on the disk. You must use an acid-free solder flux and silver-bearing solder (3% silver recommended), and you must work quickly using an iron at the correct temperature for the solder or you will completely detach the silver film from the disk.
If necessary, you can find replacement disks at electronic component vendors such as Mouser Electronics. The primary specification is the frequency (musical pitch), given in Hz or kHz (Hertz or kiloHertz). If you don't have that number, getting a disk of the same diameter will probably be close enough. You'll want one with wires or PC leads already attached. piezoelectric Audio Devices Mouser
Oct 22, 2014 | Microwave Ovens
How can I turn off the beeper on my microwave?
On some models, yes. Simply refer to your owner's manual to see if that feature is available on your model.
Otherwise, see this YouTube video.
Jan 16, 2013 | Sunbeam Save price on SGS90701W 0.7-Cubic...
Spacemaker xl (1999)low volume beep
According to the owner's manual (available here), there is a beeper volume on some models in this series. If yours has one, press it and then press 0 to 3 to control the volume (0 mutes the beeper and 3 is loudest).
If your model doesn't have the beeper volume control it's just that the beeper is going bad. They sometimes do that, getting faint or quitting entirely. You can't get a replacement beeper from GE, only the entire control circuit board.
The beeper is a piezoelectric type. Radio Shack sells a variety of beepers. If you know someone who can replace electronic components, they may have one that could be used on the board. Changing the beeper for one not the same as the original would not affect the oven's operation or safety, so that's an option. I'd do that myself if I were repairing this for a friend. But you might not be able to get a professional service shop to do this because of liability concerns. They would most likely replace the entire board.
With luck, your oven just has the volume down. Hope this has helped, and thanks for using Fixya!
Feb 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Loud horrible beeper
It's a safety device, mounted inside.
Feb 12, 2009 | Emerson Black Microwave Oven
Clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
Jan 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Is there a wy to disconnect the beeper?
Looking at the owner's manual, there is no shutoff listed.
One way to make it quieter is to put a piece of electrical tape over the piezoelectric beeper.
To silence it, you would need to cut one connection to it, desolder it, or simply break it off.
Disassembly & safety info:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Nov 30, 2008 | Sanyo EM-Z2000S Microwave Oven
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Jun 05, 2008 | Kenmore 80809 Microwave Oven
Turn off Beep on old Magic Chef microwave
On some older models, there is a sliding switch on the bottom edge of the control panel that turns it off. I've seen these on older Amanas, but not sure about others.
In newer models, they have some kind of help key which will get to to a menu which will turn it off.
Other models in between usually don't have that feature. In such cases, I as a technician have removed the beeper or taped over it to make it quieter, or even lifted one leg of a resistor attached to the beeper.
Someone less technical or less patient could just push the beeper sideways until it snaps off. No more beeps! *grin* And really, it is much weaker than the circuit board so it's a viable, if inelegant solution.
One other thing is to call Magic Chef with your model number:
http://www.mcappliance.com/contactus/contactus.asp
Nov 14, 2007 | Microwave Ovens
Microwave Ovens Logo
272 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
