Question about LG CHOCOLATE VX8500 Cellular Phone
BROKEN (front) LCD Display for LG Chocolate 3
I need help! Is there site that can help me with fixing my broken LCD screen for the front display?
  • 8 more comments
  • Anonymous Dec 24, 2008
    i broke my frount n back and i wanna know if virizon can fix it
  • corrnd Feb 05, 2009
    The outer LCD screen has a big black spot in the middle of it and lines across the screen vertically and horizontally. I'd say it looks like the screen was hit very hard in one spot except that the plastic outer cover for the front has no visible damage. Who knows what caused it.
  • Anonymous Feb 12, 2009
    Same problem
  • Anonymous Mar 03, 2009
    Same With me
  • Anonymous Mar 06, 2009
    same
  • Anonymous Mar 27, 2009
    The front screen of my chocolate 3 is broken too.
  • brittanyy521 Apr 30, 2009
    I believe I have a similar problem...I was just sitting around texting one minute...then I closed my phone...and the front screen looked like it had been hit with something really hard...there is a black spot that looks like 'ink' and there are vertical lines and a white spot...there is no damage to the outside screen itself...and the inside works perfectly..it just looks as if it was smashed on the inside of the front screen..but i didn't drop it or sit on it or anything..i have no idea how this would have happened?
  • pwagenman May 07, 2009
    I have the exact same issue. Called Verizon and they said they could not replace the phone because it was a hardware failure. What can someone do to get this replaced?
  • Anonymous May 10, 2009
    I have the same problem. My phone just started to do it yesterday and now the color is all washed out. there is a thick black line down the middle and bunch of little black lines branching off of that.
  • Anonymous May 11, 2009
    same here i was in class and it first appeared as a thin line and now its larger.
Search for "chocolate 3 lcd" on Ebay. For ~$26 and a little technical work you can replace the outside & inside LCD module.
Posted on Jul 11, 2009
  • 1 more comment
  • 35charlie Aug 02, 2009
    Scratch what I said about Ebay. I got one from the seller there and it didn't work right. I returned it and they sent another that had the same problem. It probably isn't the right model for the phone. I bought one from http://www.globaldirectparts.com/LG-VX85... for $31 shipped and installed it tonight. It works perfectly!
    Replacement is fairly simple but you'll need a small jeweler's or glasses screwdriver. Here's how:
    1. Open the phone and remove the 4 round stickers covering the screws in the corners.
    2. Remove the 4 screws then carefully pry along the edge to pop the cover off. Once you get it all "popped", it will lift easily off. ***Be careful not to pull too hard on the cover since the ribbon cable connected to the thumbwheel is still attached.
    3. Close the phone and set it screen side up. Turn the thumbwheel cover 90 degrees to minimize tension on the ribbon cable and allow access to the LCD.
    4. Near the camera, *gently* pry up on the orange ribbon cable going to the camera. It should pop up and fold up over toward the camera.
    5. Under the camera ribbon cable, *gently* pry the ribbon it plugged into upward to seperate it from the LCD ribbon connector below it.
    6. Pry under the LCD and lift the bottom end out from under the ribbon cable angling across it. Once it's partially lifted out you may need to work a small screwdriver under its ribbon cable connector since there's a sticky surface below it to hold it in place. Gently wiggling the LCD module side to side helps it come out.
    7. Remove the LCD, and put the new one in in reverse order.
    8. Click the ribbon connector back into place, followed by the camera one.
    9. Turn on the phone and see it all work.
    9. Snap the cover on, replace the screws and stickers and you're done!
    One more thing: You can see pictures of all of the insides of your phone (or any FCC registered device) on the fcc site here:
    https://gullfoss2.fcc.gov/prod/oet/forms...
    Down at page 7 and below you can see the LCD and ribbon cable connectors.
Lg chocolate touch screen not working
I have a LG Chocolate BL 40. It fell down and cracked its display screen from several loactions. So I got a the cracked display screen replaced with a new one. All seems to be working fine except that when the call comes the answer button which used to display as green gets greyed out and does not lets you answer the call. I have tried upgrading the software as well as a factory reset bit it has not helped. C
Can somebody advise how/if it can be fixed?
Aug 28, 2010 | LG Chocolate 3 Cell Phone
Screen broken
Nigel-
Here is a link that shows how to replace the broken LCD Screen on the LG KF700. There are links to buy a new KF700 LCD screen
LG KF700 LCD Display Screen Replacement
Nov 07, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
Nokia 6288 Broken front screen and LCD
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Dec 18, 2008 | Nokia 6288 Cellular Phone
LG VX8500 DISPLAY PROBLEM
The flex cable is broken.. not user replaceable unless you're really brave..
Jan 10, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG CHOCOLATE MOBILE PHONE
No way to fix. You must replace LCD Sorry
Dec 22, 2007 | LG KG800 Cellular Phone
LG 800 screen suddenly turn white
-There are display settings in your mobile, display item,u can check u settings from there
- Contact LG care center
Nov 03, 2007 | LG KG800 Cellular Phone
Nothing Display in Canon Ixus 750
Explain how broken Does the Screen display anything? If it does but is cracked then clear tape will fix it. If it is 'dead' then nothing will fix it and no repair I would think is possible. But to be sure check your local web site for repairers or even Canon - but possibly not in Bangla
Aug 11, 2006 | Canon PowerShot SD550 / IXUS 750 Digital...
LG CHOCOLATE VX8500 Cellular Phone Logo
3,277 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
