Question about ASUS K8V-MX Motherboard
Black screen and three beeps
Please help me.
I have a Asrock M266A mother board with 512MB DDR333 memory, i tried to add another 512MB memory and after that my screen is showing black and beeping three times repetively after couple second.
My computer specification is followes:
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 3 Build 2600
OS Manufacturer Microsoft Corporation
System Manufacturer VIA
System Model M266A
System Type X86-based PC
Processor x86 Family 15 Model 2 Stepping 9 GenuineIntel ~2798 Mhz
BIOS Version/Date American Megatrends Inc. P1.40, 4/9/2003
SMBIOS Version 2.3
Hardware Abstraction Layer Version = "5.1.2600.5512 (xpsp.080413-2111)"
Total Physical Memory 512.00 MB
Available Physical Memory 48.03 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 1.10 GB
I removed new memory and checked only with old one but same problem, then i try reset CMOS, i also check my memory in another computer it is working there, i check with another power supply but still same problem. I have a inbuilt VGA card but i also try another VGA card which is working in my friends computer but no change.
Please help me to fix my problem
  • 1 more comment
  • shah_ketul Dec 07, 2008
    I did try another memory VE32X64B-266, which was working in another PC, but i have same problem.
    I try another memory VE32X64B-266, which was woking in another PC but i stall have a same proble.
  • a_sheck Dec 25, 2008
    I have a similar problem. I took my memory,which was working nicely, out of my AsRock M266A motherboard and put it in a next motherboard for testing. This other motherboard doesn't work for different reasons, but when I replaced the RAM into the AsRock motherboard I'm getting the 3 long beeps, which I know is associated with disfunctional or incompatible RAM. The motherboard is now rejecting all sticks of memory, even SD RAM which was previously used in it.
    Any suggestions would be helpful.
Your m/boar is now not supporting the ddr which you are putting in, so you have to replace your ddr with Kingston DDR it'll solve the problem
Posted on Dec 06, 2008
I have motherboard Asrock M266A R3.0 I need to know the max of ram able to work at this mother
2 x DDR, DDR266/200 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Mar 25, 2014 | Asrock Computers & Internet
Computer hangs on when in BIOS. also hangs when plaaying simple games like bookworm
hello...try remove all data cable connection/HDD IDE/SATA connection,CD/DVD IDE/SATA connection and then try to..if their is same happen try remove the memory then clean using a paper eraser all pin connestors..thanks and good luc to you..have a nice day
May 16, 2009 | Asrock M266A Motherboard
Averatec 3200
If your laptop has an AMI bios, 3 short beeps indicates a problem with your RAM. Unplug the laptop, flip it over and remove the battery. The RAM is located under the panel with the Microsoft Proof of License sticker. Try reseating your memory and see if that helps. If you need to replace your RAM, it takes DDR333 SODIMM (512Mb is running about 30USD)
Sep 21, 2008 | Averatec 3200 Notebook
Asrock K7S41GX "NEW" does not work :bip-bip-bip
3 beeps is a memory error. remove the memory and put it in the first slot.
also the memory replacement calls for ddr pc2700.
Robert
Sep 05, 2008 | Asrock K7S41GX Motherboard
PCI driver
Hi
Here is driver for audio http://driverscollection.com/?file_id=34694
please inform me about other drivers what you need...
Thanks
Jul 13, 2008 | VIA ASRock K7VM3 Socket A/...
Hello I have a motherboard Asrock nothing works
check all possible connections from your power supply to the motherboard.
May 28, 2008 | Asrock M266A Motherboard
Pc does not boot
my pc is asrock m266a board intel pentium 4. it does not boot nor reach to bios startup nothing shows on the monitor ketbord and mouse are off only the fan runs i tried to take everythin out and assemble it again no results found pliz help . moses
May 07, 2008 | Asrock M266A Motherboard
RE: mother board not going on
Hi marlonvig, what type of memory (PC3200? or PC2700) memory are you using? What type in which slot?
The decription (In you're manual), refering to you're memory can be confusing.
You're manual says you can use up to 1GB of
PC3200 DDR400MHz only in Slot 1.
If you add DDR400MHz into slot 2. The board will not support it. (weird)!
If you want to reach 2GB of memory. You must use PC2700 (DDR333)MHz. 2x1GB PC2700 = 1GB DIMMS in both DIMM 1 & 2. You're board does not support DDR2 type memory.
Need you're manual? Download it from this link. Click on it.
http://www.asrock.com/mb/manual.asp?Model=775VM800
Asrock's home page for you're 775VM800 board.
http://www.asrock.com/mb/overview.asp?Model=775VM800
Mike
Apr 28, 2008 | Asrock 775VM800 Motherboard
Can asrock m266a support geforce 8600gt
Dear hiran89
Please see the specification of your motherboard at the following link of Asrock. It supports only up to AGP 4x.
http://www.asrock.com/mb/overview.asp?Model=M266A
The 8600GT GPU does not come in AGP setups only PCI-Express. In general even if you were to have this card then the rest of your system would bottleneck the capabilities of the card.
My advice is to buy something more suited to the system you own such as a RADEON RX2600PRO, GEFORCE 7600GT,..but still these may be still more than the system deserves right now.
Saying this the most powerfull graphics card now in AGP are the ones below
GEFORCE 7900GS, 512MB DDR3
ATI HD 3850, 512MB GDDR3
Regards
EngineerGR
Apr 28, 2008 | Asrock M266A Motherboard
ASUS K8V-MX Motherboard Logo
454 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
