Question about Amana Heating & Cooling
Amana heat unit led flashes code 3 what does that code mean
  • 85 Answers
Can you find the manual and see what it reads? It would help allot, sometimes theyare on the furnace door somewhere, even inside the cabinent. Let me know, if not then we can go step by step to try to figure out your problem, and save you money for a tech to fix it.
Posted on Dec 06, 2008
I have an Amana Air Command 80 SV Natural Gas fired Furnace that is roughly 19 years old.
it should be above the burner on the outside of the heat exchanger square is shape
Jan 17, 2017 | Amana Heating & Cooling
I have a Amana unit Model# PGA60C1152F that has a blinking light on the control board it blinks 4 times. That heat will come on then go off but the blower nevers comes on.
look on the inside of the door that you took off and there should be a diagram and on that there will flash code that will tell you what 4 flashes means.i think it is a flame rollout or high limit.
Nov 16, 2012 | Amana Heating & Cooling
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
My Amana asx 16 seer 4 ton system installed 3 years ago quit working. The alert light is flashing 6 times. What does this mean?
Hi if you are looking at the indoor unit and this is where you see this flashing light, remove the panel. The circuit board is where this led light is. You will also have a 3 to 5 amp fuse plugged into the board. Look for a chart on a panel door. It will be glued there. It will tell you what the problem is according to how many times it flashes. Could be several different safety switches. Make sure there is no door panel switch on the indoor unit, has if there is, the unit will not run after you remove the panel, it kills power to it. You may need to tape it down so you can have power to run it and check it out. Is the indoor unit a gas system or is it a 4 ton heat-pump? If you cant find what I have said, get back to me after checking these things and let me know . Check all breakers. Let me know if this is a package unit or a split, indoor and outdoor unit, or all in one. I will wait to hear back from you on this.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Jun 29, 2010 | Heating & Cooling
I dont know how to pull the codes on a 1993 volvo
Volvo Code Retrieval Accessing Trouble Codes 89-93 models (and later non-turbo/non-OBDII models)
Fuel Codes Locate the diagnostic unit behind left strut tower and remove its cover.(see image) Connect selector cable to socket #2,which tests the fuel codes. Turn the ignition switch to the ON position(engine not running). Enter the diagnostic mode by pressing the push button on the diagnostic unit for at least 1 second, but not more than 3 seconds. The red LED light will start to flash,count the number of flashes in 3 flash intervals. The flashes will be seperated by 3 second intervals.Make note of all codes. If no codes are stored,the LED will flash 1-1-1,which means the fuel system is operating correctly.
Ignition Codes To access the ignition codes,follow the above procedure,but with the selector cable connected to the #6 socket on the diagnostic unit.
NOTE:Turbocharged models may have seperate codes for the turbo system and are accessse by hooking the selector cable to the #5 socket.
Rate this.
Dec 28, 2009 | 1994 Volvo 940
Arcoair central heat /air conditioning unit
The blower motor kicks on when there has been a 24 volt control failure.
This usually means that a limit switch has tripped.
Most likely that would be a high temp limit switch or a rollout switch.
First, make sure the filters are clean. and the evap coil is clean. If eaither are dirty/clogged, it will partially block airflow, causing the furnace to overheat, causing the high temp limit to trip.
A rollout switch typically trips for three reasons.
1 flame rollout into the burner compartment due to poor airflow.
2 overheating af teh metal plate the rollout is mounted to, due to dirty, old, rusted components.
3 a bad limit switch.
If your unit has an LED light, count the flashes and it will hepl popint out the problem.
(locate the wiring diagram/flash code list, and correspond the flash count, with the code.)
First, check filters.
Jan 14, 2009 | Heating & Cooling
Flashing Red Led on Amana PTH123A50AB
i can help with this call 1-888-855-9987
Aug 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana PTC153A50AD Electric Heater
1. copressure not working.
2 check spare parts of a/c.
3 wiring
Feb 02, 2008 | Amana PTC153B50AJ Electric Heat Air...
Amana ptac
WHAT DID YOU DO TO IT?
Sep 10, 2007 | Amana AAC051FRB Air Conditioner
Heating & Cooling Logo
110 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
