Question about Memorex MKS8503 Personal CD Player
Got a Karaoke machine and cant skip songs I dont like anymore
I got a Memorex MKS8503 at first it worked well but a couple days after I got it I was no longer able to skip to the next song if I didnt like the current one. Everything else seems to be working well except for the >>
0 characters
1 Points
Are manuals and/or parts available, md6250cp
I can only suggest that you go to this webpage
and either contact support, or use ask a question form for pukka information (assuming I am correct in thinking that this model is manufactured and sold by Memorex)
Other than that, I can only suggest buying/asking a the seller a second hand machine that comes with a manual.
Manuals for Memorex portable CD players do exist, but not it seems for the MD6250CP, I don't how similar they are. Meorex support might be able to answer this too.
Sep 24, 2015 | Personal CD Players
Memorex mp4047 Personal CD Instructions needed
You may download a copy of the user's guide here.
Dec 19, 2012 | Personal CD Players
I Lost the dam instruction Guide and I cant figure out how to turn it on... It pisses me off that yall cant make one online! So please tell me how to turn it on...
unfortunately, the service manual for your Memorex MD6451R Personal CD Player is not available anywhere online. The manufacturers of this Unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of your Memorex MD6451R Personal CD Player via phone or e-mail and request for the service manual from them. They might give it to you or direct you to a dealer where you can get the service manual.
This is the best you can do to get the service manual you are requesting for.
Also there are similar manual for Memorex Cd player that you can use as a guide tool.
Good luck.
May 30, 2011 | Memorex MD6451R Personal CD Player
Where is the power button?
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you with your question. You want to know where the power button is on the Memorex MD6451R Personal CD Player? Well to answer your question, the power button is Play/Pause button. Insert a CD into the compartment, close the top and press the Play/Pause button (whether on the CD player or the wired inline remote). I hope this turns on your CD player and thank you for choosing FixYa to answer your question. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 28, 2011 | Memorex MD6451R Personal CD Player
My memorex MD6451 CD player is giving me an "ER" message and will not play my CD. I have no idea of how to repair this. Can you help me?
It is quite possible that your Cd has a faulty optical head which does not read the data from the cd. Hence the error message. What you can do is to clean the lens of the optical head and try again . If not then you will need to replace the head but seek help if you have not attempted any electronic work as there are many delicate details to follow with the replacement specially with the solder short on the new unit.Also to evaluate the cost of the new unit is also required. Hope you try this out. Good day
Aug 09, 2010 | Memorex MD6451R Personal CD Player
I downloaded a couple of songs from limewire and now i want to put them on my mp3 but i dont know how to
Just connect the MP3 player to your PC. Then drag & drop the song into the MP3 player. Unless the player comes with some special software.
Sep 19, 2009 | Coby MP-CD521 Personal CD Player
When I press the play button, the cd goes around, but it stops
its either you have a defective pick-up lens or spindle motor.
Aug 06, 2009 | Personal CD Players
CD won't read, radio works great.
Is It On Hold? There Is A button On The Side Usually That Says Hold. Also Try Cleaning The Lens Maybe Being Very Gentle Use A Q-Tip And Rubbing Alcohol.
Jan 05, 2009 | Durabrand Anti-Skip CD-915 Personal CD...
Mp3 saying can not create file
ok I figured it out. When u drag the songs or files to the mp3 player initially, they all go into the folder ROOT. What you need to do is delete a song or two and create a new folder. To do this, connect mp3 player to the computer, open the e:/ so that you can see the songs or files that you have put on there. Then click 0n file, go down to new and then click on folder. This will show a new one on the info of mp3 player. Then drag anything you have on the player to the new file. You can then add more songs, ect. Just keep transferring them to the new folder as you download. It fixed my problem because at first it would not let me have more than about 100 songs, now I have about 450. Hope this helps!!!
Mar 22, 2008 | Innovage Personal CD Player
CD Player Acting Up
some cd players have a feature that is called intro. it plays typically the first 4 to 10 seconds of a song & goes to the next track. it does this to every song on the cd. see if intro is on your display or if it's turned on in the menu. i hope it works. good luck.
Jan 04, 2007 | Aiwa XP-R230 Personal CD Player
Memorex MKS8503 Personal CD Player Logo
Top Memorex Personal CD Players Experts
Todd Zettlemoyer
Todd Zettlemoyer
Are you a Memorex Personal CD Player Expert? Answer questions, earn points and help others
