Question about Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 04 plate
My blaupunkt 5 disc cd player doesnt work anymore just switchs straight back to radio
  • 3 more comments
  • djsaul Dec 08, 2008
    it flicks onto disc one flashed green on disc one, all the others flash orange then it goes back to radio, if you find out please let me know what can be done to fix it, cheers, dan, no1jdfan@hotmail.co.uk
  • Anonymous Dec 18, 2008
    same with mine mate
  • diasd724 Dec 29, 2008
    I have the same problem - it starts to work again on its own after a while.
  • mikwillo Apr 02, 2009
    Mine is the same. Did anyone try disconnecting it? If so, did this resolve the problem?
  • johnhipkiss Apr 25, 2009
    Exactly the same problem , having purchased a second hand Peugeout 307 , 02 plate , I find the CD changer does not respond and the radio switches back in .
Just disconect leads on cd changer should reset
Posted on Dec 19, 2008
    New Friend:
I used the double pronged sterio clip release things that you poke in the 2 holes either side of the unit to release the fixings then pulled the unit out disconnected the blue plug from the back by first pushing the black plastic retaining clip to the side which releases the blue plug. I then took the unit indoors, gave it a tap on all edges, removed the metal top by depressing the small recess clips on the edge then sliding the side beack and removing it. I then gave it a damned good blow in all areas inside. I then reassembled, reconnected and tested it before I pushed it all the way back in until it clipped back into the fixings. It works perfectly !!
Posted on Sep 11, 2013
When switch on the CD, Blaupunkt IDC A09, the red LEDs for all the eject buttons begin to blink.
Posted on Aug 16, 2009
Hi Can anyone be kind enough and give me a code for blaupunkt 2040 from my peugeot 206? 14 digit code is BP8146x2387842 and the 10 code is 7648146392. Many thanks
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Peugeot service centre and get them to enter this code for you.
Dec 04, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 Audio
Anything is possible with a bit of fore thought ,take old one out then try to fit the new one the wiring plugs should be the same for two of them but the third one will work the changer so leave that disconnected
Nov 29, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
How can get blaupunkt radio code for peugeot 206
go to the torrent site thepiratebay.org and download the radio decode package and their are numerous packages in this download including the one you need ,watch the antivirus though as it will say they are all viruses but beleave me i havent had anything untoward form this package it is just they .exe programmes and the antivirus doesnt like this sort of programme
Feb 22, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
My cd changer came with lead that doesnt work where can i get one from?it is a blaupunkt idco4
Simple answer: Ebay!
Search for "changer cable", it will come up as either peugeot or citreon changer cable
Mar 10, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 BP905038637756 7607769050, code please?
PEUGEOT Blaupunkt
There may be 2 different codes depending on how old the car /radio  is.
Try 3963
and if your radio will not accept any digits higher than 6 ( ie 6666 is the highest  )
then try 2211
Sep 04, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Oct 28, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd changer will not work
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
Jan 09, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd player
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Mar 11, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5-Disc CD Changer Logo
2,705 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
