Question about Philips GoGear HDD6330 MP3 Player
Does Gogear charge via the USB plug or only via the 13 amp plug
There is on the market a car cigarette lighter adaptor with a VHF transmitter and a USB port. I would like to use this to paly and charge to Gogear in the car.
    New Friend:
  • 161 Answers
You should be able to use the play side but I do not think you will be able to charge it.
The transmitter side is taken from the earphone socket.
The power comes from the mains plug via. the Philips lead and is at 5 volts.
I could be telling you wrong as I do not know what adaptor you are looking to purchase.
Posted on Dec 06, 2008
Mercedes C200 Classic W202
there is a device on the market that plugs into the cigarette lighter socket from which you can charge the car battery
it has a small 12 v battery in it and this gives a voltage to activate the car battery
try auto spare shops and battery shops for it
it may also be available fro a good tool shop in the battery and elecrical section
May 22, 2015 | GPS
Charg wildfire s
You can Charge a HTC Wildfire S via a wall socket (240V Australia) the cigarette lighter in your car or by plugging it into any USB port. The phone comes with all the hardware to make use of these options.
Oct 04, 2013 | Cell Phones
I am having trouble charging an invacare portable oxygen concentrator in a 12 volt adaptor ( cigarette lighter plu in) without it blowing fuses
the plug in unit is probably drawing more amps than the lighter socket will cater for. Check that the fault is not in the unit. Check for total current draw of the machine. As a last resort use the machine directly coupled to the battery
Jul 14, 2013 | Cars & Trucks
Need car adaptor for bmr100 12v to12v
As they don't make one you have 2 options.
1) Buy another Mains Adapter and Cigarette Lighter Plug, Cut the Cable & Connect to the BMR100 and connect it to the Cigarette Lighter Plug.
2) Buy a small (100W) 12V to 240V Inverter and plug your existing Mains Adapter into this. You'll get one from eBay for about £10.00 to £15.00.
May 05, 2011 | Makita BMR100 Radio
Is there a device i can get so i can listen to my phillips gogear through the car radio
You can buy an FM transmitter. They have styles that plug into the cigarette lighter in your car, or some that will take batteries. Most that I've seen are of pretty good quality, I have one made by Griffin.
Jan 15, 2010 | Philips GoGear HDD060 MP3 Player
Nuvi 350 wont charge with car adaptor. But charges with ac charger in usb port of Nuvi. Any thoughts? I have another Nuvi 350 that does charge with this ones car adaptor.
Are you using the same port on the Nuvi to connect the car adapter and the ac charger, or two different ones? If not, then the jack could be broken (solder joint, pin?).
Aug 10, 2008 | Garmin Nuvi 350 Car GPS Receiver
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Just bought a new Philips MP3 Player Model SA3025/37 and was wondering if I can use it in my car?
You can use any MP3 player in your car by connecting to an FM transmitter.
Look for FM transmitters on E-Bay.
They are powered by either battery, or cigarette lighter adaptor.
They plug into the headphone socket of the MP3 and convert the output into an FM signal, which you can tune your car radio into.
Jun 07, 2008 | Philips Audio Players & Recorders
How to recharge the unit
you can charge it via the usb or cigarette lighter.  either method will work and i am not aware of any problems created by using the lighter.  that really should be the primary charge method as it is expected to be used in the car.  is it charging on your computer.  if it is, but not on the lighter you may want to ensure that the lighter is itself working correctly and then also check to make sure that the fuse in the car charger is intact.  just a few suggestions
Dec 25, 2007 | Garmin StreetPilot c510 Deluxe GPS...
Philips GoGear HDD6330 MP3 Player Logo
66 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
