Question about Yamaha HTR-5240 Receiver
Will not stay on
When I turn on the system it comes on and the turns itself off within a second or two.
Hello-
I had the identical problem and solved it. It is a short where the speaker wires are contacting each other. Since my problem only happened when a DVD movie was being played, it had to be either the center or back speakers. Checked the center and found both speaker wires touching each other. A little wire shortening and stripping and re-connecting without contact solved the problem.
Everything is working perfectly now.
Good luck.
Barry Scholles
Strasburg, OH
Posted on Dec 30, 2008
When I turn my projector on within seconds it turns itself off
Are the fans all starting up? The symptom you describe is often associated with a faulty fan. Also could be a failed lamp, as the projector will shut down if the lamp does not strike within a defined time, although in this case the 'lamp' light should come on
Mar 31, 2014 | Sony VPL-CS7 Multimedia Projector
Tip
How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe
Hi, on most vehicles, the airbag light should come on for at 6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident. <br /> The flashing light on your car is telling there is a problem. <br /> <br /> <b>How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe </b> <br /> Ignition Key Method: <br /> <ul> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 2 seconds.</li> <li>START Car (the light may be blinking slower than before).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 3 seconds.</li> <li>START Car.</li></ul> <br /> <b>This is a little easier</b> To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
on Dec 07, 2010 | Infiniti G35 Cars & Trucks
Psu wont turn on
Test the PSU. Unplug it from the motherboard and then with nothing connected, short the green wire to any ground (usually a black) using a paperclip and it should come on and stay on if the problem was with the motherboard/computer but if it shuts down, then you know the problem is the PSU itself.
If the PSU stays on under no load, then one possibility is you had too much connected to it and it shut down as a protective feature. The Bios would not beep if the PSU is shutting itself down. Also make sure you have the internal speaker connected. It's possible you just can't hear the beep because there is no speaker connected or it may be connected to the wrong place.
Don't throw away a defective power supply. It is worth a couple bucks as parts for an electronics enthusiast. Keep it out of the landfill.
Jan 16, 2013 | RaidMax Computers & Internet
How do I reset the change oil soon message in my 1998 Chevy Lumina after changing the oil?
This is done by turning the key on engine off and fully pressing the gas pedal to the floor sloowly three times within 5 seconds, the light will blink and go off then turn the key off for 3 sec and start engine, light should be off if not repeat steps. hope this helps.
Oct 27, 2010 | 1999 Chevrolet Lumina
How do I let the computer know i have changed the oil?
Turn the ignition key to the RUN position. Fully push and release the accelerator pedal 3 times within 5 seconds. If the CHANGE OIL SOON light flashes 2 times, the system is reset. However, if the light comes on and stays on for 5 seconds, the system did not reset. Repeat the procedure if the system does not reset.
Oct 11, 2010 | 2003 GMC Sierra 1500
Turn on and it turns off by itself within a second
try to charge it maybe its low battery
Mar 07, 2010 | Nintendo DS Lite
VCR tape was hung in Sylvania SRDV495. Got the
You need the aligniament the eject gears to tape gears.Please remove the cover platen and the rear cover(bottom) and align the gears manually.Obturated the sensors hole and insert the cassette.Verify the eject and the tape belts.If you have knowlwdge VCRs the problems solved in 1 hour.
Aug 21, 2009 | Sylvania Televison & Video
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
Turns itself off within 2 seconds of being started
Lock all doors and open with key in passenger side door.Then start it..That should reset the security system>>>Hope this helps you and have a great day...
Apr 05, 2009 | 1995 Jeep Grand Cherokee
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Yamaha HTR-5240 Receiver Logo
179 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
