Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
My dyson dc 17 does not work when in the upright position
It works when the handle is back and has normal suction, but as soon as I move it to the upright position, it shuts down. What is wrong?
  • 4 more comments
  • hambone5 Dec 20, 2008
    I have the same problem. Was working with the handle removed and suddenly the vaccuum stopped. I thought it was full, so emptied the canister and put back together. It won't turn on in the upright position, it works fine when you place the handle back on and use as a regular vaccuum, but when you put the handle upright, it shuts off. This disables the function to use the handle for corners/edges.
  • skestell Dec 30, 2008
    I have the same problem.  Was working fine, then just shut off.  Took it apart, cleaned everything, including filter.  Now only works with handle in back position, shuts off when handle up, but has very little if any suction.  Has always worked great.  It is less than 2 years old.
  • Anonymous Jan 05, 2009
    You should try calling Dyson. IF you registered your vacuum then it should be under warranty.
  • sevinn400 Mar 14, 2009
    No, it is not how it shuts off the beater bar. The beater bar shuts off automatically when put into the upright position and just the suction works...when the vacuum is working properly. Our problem is that the whole vacuum just shuts off.
  • Anonymous Mar 22, 2009
    "My Dyson animal does not work when it is in the upright position or if I try to shut off the beater brush.
  • Joe Lepe May 11, 2010
    I need a better detailed explanation of your problem. What you have is very vague. Does the brush motor work, does it power off right away, any high pitched noises? Details are key.
I had this same issue today, after not being able to find a solution, I took apart the brush area by unscrewing the three simple screws... my belt had a TON of dog and cat hair built up inside it so I cleaned that out and it did the trick.
Posted on Mar 15, 2009
It is suppose to do that...that is how it shuts off the beater bar...it is ok....
Posted on Feb 10, 2009
DYSON DC 25 SHUTS DOWN UNEXPECTEDLY?
clean all access ports up the handle. plugged somewhere.
Aug 04, 2014 | Dyson DC25 Vacuum
Dyson DC 25 power shuts off in upright position
To clarify, do you mean the suction and brush motion shut off in the upright position, or that the entire unit shuts off?
If the latter, most Dyson uprights shut off the brush unit in the full upright position and shunt the suction into the handle for use with the accessories. There is also an on/off for the brush, next to the main power button for the DC25. If it's off ( or stuck that way), no brush motion. The manual also notes, 'for use, turn on power and click the foot pedal in back to recline the unit.' (Link to manual here:
http://www.dyson.com/medialibrary/files/dyson/support/downloads/uk/floorcare/manuals/DC25_Manual.pdf See Page 8). The
'High Reach Cleaning' section also notes that the brush bar won't rotate when the vacuum is in the full upright position.
If you are completely losing power, the manual notes that the unit will shut off if the bar is jammed, or if there is a significant line blockage that makes the motor overheat. If this is happening, check the accessory line in the handle for blockage.
Good Luck :-)
Jul 11, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Dyson DC 28 works great, until I remove the bag to empty it. I reattach it, clicking it carefully in place, but then I release the "tilt" thing to vacuum carpet, and NO SUCTION! I have to keep taking...
On the back of the Hoover is a couple of parts you can remove, one is a u bend which will trap heavier parts which resist the suction so get stuck in the bottom of this, and the other part is usually on the right at the bottom which is an acces point to the very art which you hear click. In the upright position it directs the vacuum suction up the extendable pipe, but when you pull the handle back, it should gently glide from one direction over to direct vacuum suction to the bottom plate. It's tha part which is getting stuck in the handle sucking direction. I'd check to see if it is physically damaged in any way or if something is tapped in it like a coin or something. Good luck
Nov 25, 2013 | Dyson DC28 Animal Airmuscle Vacuum 00247
Air escaping from top of handle
Hi there, it's Jack at Dyson.
It's part of the design of our upright vacuums that when the machine is standing upright, the suction is diverted to the wand, ready for above-floor cleaning. You can find out more about how the hose, wand and tools work on our Support page:
http://content.dyson.com/support/help.asp?article=1255&product=DC28-ANIMAL
It sounds like your machine is working normally, but if you'd like any further assistance please email us at askdysonUS@dyson.com and we'll be in touch as soon as possible.
Best wishes,
JackDyson Online Customer Supporthttp://www.dyson.com
Feb 19, 2013 | Dyson DC28 Animal Bagless Upright Vacuum
After vacuuming with my Dyson animal DC 17 I placed the vacuum in a upright position and the vacuum cuts completely off. Also the wand no longer has suction....
Hi John,
I'm sorry to hear you're having difficulties with your DC17. This issue sounds unusual, and we'd appreciate the opportunity to provide further assistance. Please call us free on 1-866-693-9766 - or if you'd prefer, email your details to askdysonUS@dyson.com. Someone will be in touch as soon as possible to help.
We'll look forward to helping you resolve this.
Best wishes,
Jack
Feb 19, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a Dyson DC28 Animal Bagless Upright Vacuum. The vacuum has no suction. the beater roller turns but there is no suction. The red button and the on off switch only works when the handle is moved...
Sorry to hear you're having difficulties with your DC28. I wouldn't suggest attempting to dismantle the cleaner yourself, as this will void the warranty.
Due to the nature of your issue, it's probably best if you get in touch with us directly - one of our experts will be happy to run through some troubleshooting checks over the phone with you, and provide further assistance. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will get back to you as soon as possible.
Kind regards,
Jack
Dyson Customer Service
Aug 08, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
When I tilt my Dyson DC 17 Animal upright so that I can use the hose, the vacuum powers off. As soon as I tilt it back down, it turns back on.
I'm sorry to hear you're having difficulties with your DC17. When you stand the cleaner upright, the brushbar motor is designed to shut off automatically. However, the suction motor should continue to run unless you turn it off manually with the on/off switch. If both motors seem to be shutting off when you stand the cleaner upright, it's probably best if you get in touch with us directly so we can resolve this issue for you as quickly as possible.
You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Jun 30, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC 14 animal bagless--unable to use wand
Hi.
Try these tests & tell me the results.
Remove the hose & wand completely from the machine it unclips at the bottom of the back.
Leave handle in full upright position & switch on do you still get the sound of something blocked ?
If yes remove the (U) shaped inspection port again at bottom back of machine now repeat last test what happens ?
Please reply with your answers.
http://dysonmanuals.llc.nu/index.htm
Chris.
May 18, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction in upright position
Check the adapters at the bottom. They're supposed to move cleanly when you lower the handle. It's pretty obvious if there's an air gap when you lower the handle, and you should hear the suction in the air gap.
And...call Dyson...their support is great!
Oct 24, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
1,805 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
