Question about Toshiba Cinevision DVR2000
Install s-video cable now dvd is black & white
Have had combo player for some time and recently installed s-video cable between player and RCA 32" television. Now all player will do is play dvd's in black and white. The picture clarity is great but it's still black and white. Cannot seem to get color. All I did was install an s-video cable. Had to resort to re-install coax connection so that dvd would play in color. Any suggestions?
  • jimmy_boykin Dec 08, 2008
    Purchased a different s-video cable and received the exact same results. Didn't think the cable was the issue, but figured it was worth a try to eliminate the concern
  • 88 Answers
You might have a bad cable just because you get a great picture but no color.i would exchange the cable where you bought it and try another one.
Posted on Dec 06, 2008
I am trying to connect a sony dvd player by rca cables to my tv and it only plays in black and white.do I need specific cables
Wallie, If possible save your self some aggravation and get a HDMI cable, if you have that option..
press the helpful button and follow me on fixya for more tips and info.
Feb 10, 2016 | Sony Televison & Video
Have a Magnavox (31YA--??) DVD/CD recorder/player which due to moving and busy, I have NEVER installed; and have at the same time lost the manual. HAVE PLENTY of cords to match colored terminals; but "S"...
The S-Video "holes" the tv and the dvd player each have a S-Video.Hook it up with a one black video cable to the S-video to the hole in the tv and the other side to the S-Video in the dvd player.U have a RCA cable have 2 plugs lead each sides have 2 connections one RED,one White lead connections. Plug that RCA cable 2 connections in INPUT holes in the Tv ,and the other sides 2 connections one WHITE,ONE RED to the DVD player for sound.
Apr 03, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Hi! I have a Magnavox DVD recorder/VHS combo. I
alot of times when the video cord gets pinched it will go to black and white you just have to replace it if that dont work. then its one of the machines.
Nov 06, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD ONLY PLAYS IN BLACK AND WHITE
figure out if yout tv and your dvd is using the same color system, check also if you installed your rca connector on proper video output of your dvd dont interchane yuv to video out connectors ,check also your dvd's video out setting ,like interlace, pc,yuv, rgb, if you are using video in on your tv you should select s-video or interlace if you are using yuv on your tv you should select yuv on your dvd
Oct 14, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
How do i/can i record tv to a DVD ]
If your using RCA cables (thats the red, white & yellow leads) you need run yellow RCA from the 'VIDEO (or) TV OUTPUT' at the back of your tv, to the 'VIDEO (or) TV INPUT' in the back of your DVD/VCR combo unit, & do the same with the red & white 'AUDIO' leads only run them from AUDIO OUTPUT(tv) to AUDIO INPUT(dvdrecorder). Now set the mode of the dvd recorder to TV IN or AUX IN. Now it should record whatever you see on the tv screen. But if your tv has an S VIDEO OUTPUT option, using an S VIDEO cable would be much easier & produces a better copy! Hope this helps!
Jun 19, 2009 | Symphonic WF803 DVD Player/VCR
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
No Color
Hi!
This sounds a lot like a setup problem. If you have connected more than one kind of cable to the unit (say, coax and RCA, or RCA and S-video), the unit needs to be told what cables to use. I'm not familiar with this particular unit, but I would bet there is a place in the setup utility where you can tell it which connection to use. Tell it to use the highest quality one you have connected and see if this fixes your problem.
Good luck and let me know if this helps!
Bob
Sep 21, 2008 | Sanyo DVW-7200 DVD/VCR
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
Toshiba Cinevision DVR2000 Logo
309 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
