Question about HP Officejet 5510 All-In-One Thermal Printer
The glass for the scanner broke, i need another one
I don't know where to by another glass for it can anyone help me
  • 28 Answers
Eek, that's a tough call.
I think the cheapest would be to take the measurements and have a local glass company cut it to size.
I've never seen a manufacturer offer replacement glass tops for their scanners. The model isn't listed, but it's probably going to be cheaper to either buy a new one or buy a broken one off ebay and take the glass out of it to use in yours.
Posted on Dec 06, 2008
Changing the glass
The glass on it broke so you should take it t your local jewelry store if you already did that take it to a profesional watch store and ask the head person.
Apr 22, 2013 | Vernier Ladies Chrono Look Two Tone...
2003 honda crv.... I need help with rear driver's side window glass. Does anyone know how to replace it? I've got the panel off and the old glass removed but that was easy 'cause some scumbag broke it for...
you have to remove the piller support ,i take it you are refering to the rear quaterlight in the back passenger door?? or the whole glass ?? in future leave nothing inside the vehicle on show and leave it open ,it has a chipped key so it cannot go walkabout .
Jun 26, 2010 | Cars & Trucks
Printer scanner failure
The motor that pushes the scanner for faxes and scanner has finally given up (or a gear broke)... Most only have a 2 year lifecycle. HP has designed it that way. I used to work for HP All in One.. whenever someone would call in for that issues, the document we used ALWAYS (for all units) said "replace" :(
Aug 11, 2009 | HP PSC 2175 All-In-One InkJet Printer
I don´t know where is located the scanner glass in my hp psc 2110 all in one
The Scanner glass is located on the top of the device under the grey cover (This cover will lift exposing the scanner glass)
May 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
30.01.19 Problem
You may have thought you were contacting HP directly, but you did not do so...Please go to this link to see the parts breakdown for your scanner. Unfortunately, I can only find the glass as a component of the entire scanner flatbed unit assembly, which would be quite expensive to replace.
I suggest you contact the HP parts replacement by email and submit a request with the details of your printer and purchase/shipping arrangements and an explanation of the damage and see if someone there cannot help you to obtain the required piece of glass, or at least the bar code needed to be scanned...the link for them is here.
If you are not successful in getting them to help, I suggest you make a post in the HP support forums, available here, where you will find many HP experts who are better able to direct your inquiries to the proper venue for a rapid solution.
Good luck in solving this difficulty!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 13, 2009 | HP LaserJet M4345 MultiFunction Printer
Changing Door Mirror Glass XJ6(X300)
Hi
You need to put on a pair of gloves, and safety glasses. (Safety First !)
Prise off the broken mirror from the plastic base that it is stuck too.
Give the plastic a clean with nail polish remover or similar.
Peel off the backing on new mirror glass, and carefully stick it on.
Good Luck !
Don´t forget to FixYa Rate Me Please !
John.
Feb 05, 2009 | 1998 Jaguar XK8
Start up problem with printer
Your scanner glass is get dirty and all scanners make a self diagnostic program when we turn on the printers.
At this point, you will hear a little noise from the scanner carriage lamp, witch is doing self calibrating. In this calibrating time the scanner unit "read" the white and the black levels, and the white (in your case) is not white, is quite gray because is dirty.
The solution is a very simple, but require much skill.
You must disassembly the scanner unit, remove any screw you see (you need an no. 2 phillips screwdriver) and very gently remove the upper side (with glass) from the rest of scanner unit. Please note that is several plastic fasteners to be disposed.
after you remove the glass (with a plastic frame) you get a small tissue of cotton and soaking with an windows cleaner solutions. Gently clean the BOTH surfaces of scanner glass.
For assembly follow the reverse procedure.
Beware to the glass, it has only 3 mm thickness. Don't broke!
Like I sad: simple problem, but require much skill. If you think is to difficult for you, please go to the service.
Sep 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
How do you clean the INSIDE of the scanner GLASS???
The service manual is avalable free through Emule:
ed2k://|file|Canon%20PIXMA%20MP750%20MP780%20service%20manual.pdf|1416152|F054D74C11BE5EEAF2F6D203362303DE|/
Dec 19, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP Officejet 7310 All-in-One Scanner problem
If the HP service cant help, then try to get a exchange, the machine usually have a warranty.
Jul 10, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 5510 All-In-One Thermal Printer Logo
185 people viewed this question
Seeker5211
Seeker5211
