Question about D-Link DPH-50U IP Phone
Dlink DPH-50U call problem
Im using DPH-50U adapter with skype to make the call using my cordless phone. I'm able to make the call successfully. But the problem is, I'm using the calling card to make international call. So I dial the toll free number. The call get connected. Then it asks me to enter the PIN number and press # sign. When I do this, it is not able to recognize my inputs. Please let me know how to input the numbers ending with #.
Thanks,
Khaleel
4 Suggested Answers
  • 98 Answers
SOURCE: i need a driver for
http://www.dlink.com/products/support.asp?pid=466#drivers
hear is the vista driver
Posted on Jan 25, 2009
SOURCE: DPH-50U default audio
I had the same problem. I just reinstalled the hardware manually through the install new hardware module in XP. Once I did that, Skype "saw" the D-Link adapter.
'I went into "add new hardware" clicked "yer, hardware is already installed" then selected the D-Link device that will be listed. You have to have the driver already installed, then let the OS install the hardware as it always does and then you should see the D-Link driver as one of the choices.
This drove me crazy too. I hope this works for all of you. Good Luck.
Posted on May 01, 2009
SOURCE: DPH-50U can't be uninstalled or reinstalled correctly
Yes, installing twice helps and also you have to plug the DPH-50U always in the same usb slot, as long as you have the same OS installed.
If you can't figure out your original USB hole, you will always have trouble...
Posted on Jun 03, 2010
I have a use d-link 50u ip phone what do i nedd to make work i don't have a manual to install
http://www.dlink.com/products/default.aspx?pid=DPH-50U&tab=3
Click on Support Resources, Pick your country and download a manual or driver, everythings there
Aug 01, 2010 | D-Link DPH-50U IP Phone
I have installed Skype 3.8 and d-link driver 1.01 on Windows xp. I can select the device from the audio setting but receive no dial tone. Please assist!
In your VoIP monitor settings there are two options to make your phone connect to voip. You either have to dail # # or # *. I would try hitting pound twice, but it's kind of tricky because sometimes when the dlink tries to connect it will flip back and forth between voip and pstn. So I recommend holding the phone to your ear and hitting # until you hear that dial tone!
Jul 01, 2010 | D-Link DPH-50U IP Phone
Need to connect my landline to skype
No Skype is DIGITAL all fax machines are ANALOG.
Jul 07, 2009 | Brother MFC 240C All-In-One InkJet Printer
Using the D-Link skype/pstn switch with a SIP account
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Jan 29, 2009 | D-Link DPH-50U (0790069289750) Router
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
DPH-50U driver using high DPCs
I had a similar problem on a pc i built. the culprit was my wireless card. i opened up the pc and moved the card from one pci slot to another. powered it on and it redetected mt card. my cpu usage went from 40-50% at idle to 0-5% depending. hope that helps
Oct 25, 2008 | D-Link DPH-50U IP Phone
Oct 24, 2008 | D-Link DPH-50U IP Phone
How to do voip calls with the regular phone
Did you read the manual?
first you press ##
then you will hear a weird buzz
then you dial 00 and then the phone number including the country code (example in canada.. you will do 00 1 450 419 0000
then you press *
so again,
## (weird buzz) 00 1 450 419 0000 *
and wait few seconds
Nov 15, 2007 | D-Link DPH-50U IP Phone
D-Link DPH-50U IP Phone Logo
291 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
