Question about Fisher and Paykel Washing Machines
Water not draining completely and causing smell in washing machin
Bad smell in washing machine - water still standing under can
  • Fisher and P... Master
  • 3,463 Answers
Go to www.washerhelp.co.uk.
Here you will find article on smells in washer, and lots of other useful information, far more than I can tell you.
I think you will find it very helpful.
Please leave feeedback.
Posted on Dec 06, 2008
My washing machine sounds like it still has water in it when i spin it and it smells musty
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
The washer smells funny. Like mildew or something. No water standing. Seems to drain.
Probably has some standing water in the pump hoses as well as the drain hoses If you do not use the machine often, then some water is left in the drain hoses and upon evaporation it may do what you smell. Pour some bleach in the tub, with water and let stand for 15 min. put it on rinse and let drain and do the smell test again.
Jan 09, 2011 | Whirlpool WTW5300SQ Top Load Washer
Water is not completely pumped out of machine, I can hear it sloshing under the bowl. Have taken back off and tipped machine and some water has come out but not all of it. It is making the house smell...
sounds like you may have some blockage between the tub and pump or pump to stand pipe where water goes down the drain,check all these areas for blockage or kinked hoses
Jan 25, 2010 | Washing Machines
I have a Maytag MAH3000AWW Washer. It will start
That is a common issue that is caused by the control board of the machine. You may need to request service to fix this issue. Usually it may be caused by a resistor. Replacing the resistor may make the machine to work for a while but the repair will not last longer. I believe that the machine control board next to be replaced. Something else may be causing the control board to go bad.
Perhaps you were able to feel a burning smell from the washer machine in previous days.
Standing water may be caused by the control board failure because the pump will not operate properly.
Aug 29, 2009 | Maytag Washing Machines
Kenmore 70 series top loadwasher does not completely drain water
the smell is raly bad because it doesnt drain all the water out , so it sits there. if all else with the machine works well, this means the water level sensor needs replacing
Jul 19, 2009 | Washing Machines
Horrible smell coming from the washing machine
Have you cleaned the filter in the washing machine?
Mar 31, 2009 | AEG 24 in. Favorit 40660i Built-in...
Hi, I have a Baumatic Washing Machine (not sure of the model) and cannot find the filter. The machine gives off an awful smell which I am trying to fix
you should find the filter but that is not what is causing the smell. common causes of smell are:
using liquid detergent - this smells like drains if used for a long period and leaves a horrid sludge in the tub. put on a boil wash with no clothers and use powder detergent
plumbed in under the sink and there is also a waste disposal unit. these pong!
no water barrier between the drain of the washer and the house drains
Jul 10, 2008 | Baumatic Washing Machines
LG Tromm Steam Washer
How do you have your drain hooked up?
I have seen people stuff the pipe so far into the stand pipe that when it goes into drain it siphons the water back. The water doesn't go all the way into the unit, but enough that the water in the 'P' trap moves, gas can then come up from the sewer. Make sure your drain pipe is hooked up properly. It should also not be a sealed fit either.
Sgt 48
May 08, 2008 | LG WM2688HWM TROMM SteamWasher
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
New Bosch water not draining
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Open Questions:
Washing Machines Logo
182 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
