Question about Kitchen Ranges
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a clicking sound, like it's trying to reignite itself) and needing to be re-lit several times. This goes on every five minutes or so for about half an hour, and then it kicks in and stays lit. Often times too the 'flame out' and 'grill' light indicators on the front of the oven will be lit up, even though the flame isn't out, and the grill isn't on. Have found the oven works best if the door is left wide open for about 15 minutes when it's first lit. Seems like it needs the oxygen? I close the door slowly and wait a while, and if the clicking sound starts I quickly open the door again and the sounds stops and the flame stays. I'll wait another 5-10 minutes before closing the door, and usually by this stage it works. Now, however, it won't light at all, and I really need it fixed. Just hope it's not too serious.
    Habit-Forming:
  • 171 Answers
This one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the pilot.as long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Posted on Dec 11, 2008
Hotplate won"t turn off st george cc-600 cooktop
I have a St George glass cooktop with temperature sensor light.It takes forever for the light to go out when I use the main element and that section often feels like it is still heatinglong after it has been turned off.Can there be power leakage through the switch for the main element
Aug 21, 2010 | Ovens
Hi the temp on our st george oven, model ueo-8 has become unreilable?
if digital the replace the oven control / if dial then the dial is at fault . mm
Jul 12, 2010 | Ovens
Readout on control panel has faded so that you can hardly see it. Sometimes does not turn off oven causing overheating alarm. Have to turn off at power box. Is it expensive to replace control panel? St...
It is less expensive than replacing the whole stove if you do your self. Should be able to find parts a repairclinic.com. Hope this helps.
Feb 02, 2010 | Ovens
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
St George DEO 7 oven temperature not going past 170
Merrillie,
we have this problem too on the top oven. I used to work at StGeorge and I'm an engineer, so if I find a fix, I'll let you know.
Simon
Sep 06, 2009 | Ovens
Kitchen Ranges Logo
379 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
