Question about Refrigerators
My maytag side by side model #RSW22EODAM refrigerator door has a
Gap at the bottom left side that allow air in. I had a repairman out and he said that it need some king of shims but he did not have access to them. Can you tell me what to do?
  • 114 Answers
If all you need are shims, use washers (either plastic or metal) with an interior hole large enough to go over hinge pin to raise door. However, in reading your complaint, I feel as though shims (or washers) may not solve your problem. You may have an issue with the door seal and or door liner. Sometimes a new seal will correct the problem but check for any cracks in the door liner. If cracks are evident, you will need to replace both. Putting a door seal on a cracked liner will NOT help. If you need to replace both, it can get a little costly. Good luck.
Posted on Dec 06, 2008
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
My new side by side refrigerator doors are to far apart. The gap between the doors is wider towards the top then the bottom. How wide should the gap really be and can I adjust the doors so they are...
If you loosen the bolts that hold the hinges on, there should be a small amount of play that will allow you to square up the doors. The gap between the doors should be just wider than your fingers, so they don't get pinched.
Nov 29, 2010 | Refrigerators
Refrigerator door not closing
look at bottom of door. there is a metal bracket called your door stopper. this only allows door to open so far. if pushed open to far then you bent this bracket. bent back to normal position. your door will close
Jun 21, 2009 | Whirlpool Refrigerators
French door refrig..right door pops open when left door is closed
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge
Check your door gaskets for any gap that can allow warm air into the doors.
Jun 03, 2008 | Maytag 22.6 cu. ft. Side-By-Side...
I have a maytag refrigerator model 71184100 and there is water in the bottom of the refrigerator. It is a top freezer model with an ice maker. HELP! I cannot get the freezer floor out to check to see...
that is not a maytag model number. the model number will be in the refrig section (usually) and (usually in the uper left side) look up and to the left. find that and i will help no problem. but i am thinking you have a model that is about 12 to 18 years old that model is easy to do but you need to take the doors off first, then the center trim comes out, (it has screws some are used with door hinges) and the whole bottom slides out to you
May 15, 2008 | Maytag Refrigerators
French doors
There is a drain in the bottom of the box to allow water to run out into the pan under the unit. Sounds like it is plugged up causing air pressure to be able to build when you shut either door.
Jan 27, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag (Amana) ABC2037DES Refrigerator not cooling
Your condenser coil is frozen up with condensate...need to fix the defrost system, most likely it is the control sub module.
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
Concaved out freezer door
If concave is severe you will have to replace door. You can try to alleviate a slight gap by using a hairdryer and blowing hot air on the gasket in the area of the gap....move the dryer in up and down motions and the gasket will expand! Just make sure that there is no ice pressing against the door inner first! Oshie
Jun 18, 2007 | Maytag MTF2195AE Top Freezer Refrigerator
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
