Question about Ricoh Aficio AP3800C Laser Printer
Problem for ricoh cl3000 color printer
I clean up whole machine where it necessary, after toner spread all over.then have a message said" set transfer belt unit or wast toner battle" could you tell me what's the problem or somewhere I missed to clean and where is?
    Genius:
  • 1,550 Answers
When you cleaned you have disturbed the
The belt has come out of the position check it .
You need to position the belt back to correct place .
Posted on Dec 06, 2008
A blank vertical line appears on every page printed
if it is a white void check laser shield glass. toner might be on it causing this problem. There should be a wand in front door use to clean laser area make sure you do each color. hope this helps.
Feb 09, 2014 | Ricoh Aficio CL3000 Laser Printer
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
My RICOH AFICIO CL3000 give me an error message SC441, what to do ?
Did you just replace your color PCUs (photoconductor units)? If so, one of the new units may be defective. Try reinstalling the old units to see if the problem goes away (after resetting the machine). If it does, you can replace the PCUs one by one to see which one is bad.
If you still get the sc441 even with the old PCUs (or if you don't have them anymore) install a set of new PCUs and that should fix the problem. On the off chance the problem doesn't go away even with new PCUs, contact your local service company because you may have a bad circuit board, motor, or gear.
Nov 15, 2010 | Ricoh Aficio CL3000 Laser Printer
Replace waste toner. what does it mean?
open the cartriage their are a waste toner in your cartriage cleane the cartriage then use
Oct 03, 2009 | Office Equipment & Supplies
Error message on my Ricoh CL3000
what do you mean changed color, please elaborate so i can help you out, in similar scenario it could be a sliping clutch that controls the developing unit causing the respective color to disengage while working on, M, C Y, K pls identify which is which, if you can try one of each color independently as a diuagnostic then youcan start from there which color is malfunctioning,remember the combination of each color depends upon each other color, thus maybe is the reason you can see a sudden changed of color
Jul 07, 2008 | Ricoh CL3000E Laser Printer
Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 17, 2007 | Ricoh CL3000E Laser Printer
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Ricoh Aficio AP3800C Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
