Question about Slant Fin Cool Mist GF-220 Humidifier
Lost instruction manual
I have not used my slant-fin and don't have the instruction manual and need it. Any way to get another one? Anyone have the number for the manufacturer? Thanks!
  • Anonymous Jan 08, 2008
    where exactly do the pads go? Where is the hot water reservoit?
  • Anonymous Jun 16, 2008
    need manual
  • 944 Answers
Slant/Fin has sold the humidifier and PC-55 air purifier business to KAZ USA Inc. If you need replacement parts, repairs, or have any questions regarding the products, please contact them at: KAZ, Consumer Relations Dept. 250 Turnpike rd., Southborough, MA 01772 Phone: 800-477-0457 email: info@kaz.com also worth a look is: http://www.achooallergy.com/slantfin-operating-instructions.asp seems to be best forum for humidifier stuff
Posted on Feb 28, 2007
Slant fin doesnt turn on
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Jun 23, 2014 | Slant Fin Humidifiers
My thermostats call for heat but the heat goes off and on.circulator pumps work pilot light stays on.heat will stay on for awhile but cuts off.
Here is a tip that I wrote about heating circulator pump problems.
It will give you the information you need to learn about your circulator pump problems and solutions for it.
Heating Circulating Water Pump Problems
heatman101
Dec 17, 2010 | Slant Fin Slant/Fin 2 Gallon Humidifier
No instruction manual
FILLING THE WATER TANKS
1. Before filling the water tanks, push the POWER switch to the “OFF” position and
unplug unit. Refer to cleaning instructions.
2. Remove water tanks from base, turn each tank upside down and remove tank cap
by turning counterclockwise. Fill tank with clean cold tap water.
Replace the tank cap by turning clockwise. Tighten firmly.
3. Carefully pick up tank, since it will be heavy when full, and slippery if wet.
4. Place water tanks on base. Make sure tanks are properly placed, otherwise, the
humidifier will not work correctly.
Feb 11, 2009 | Slant Fin Cool Mist GF-220 Humidifier
The ceramic coating under the nozzle deteriorating
Check this page out. It also has the owners manual listed. https://www.appliancefactoryparts.com/humidifiers/slant-fin/gf220.html
Nov 05, 2017 | Slant Fin Cool Mist GF-220 Humidifier
How do you change the mineral absorption pad?
The pad is very easy to replace. Simply remove the water tank. The mineral pad floats in the hot water reservoir. Pull out the old one and discard if it has begun to break down. That's all their is to it.
I hope this helps.
Jan 01, 2009 | Slant Fin GF-210W 2 Gallon Humidifier
Slant fin gf-210 needed part
slant fin sold the humidifier biz to another company.  info at the slant/fin site http://www.slantfin.com/contact.php
Nov 18, 2008 | Slant Fin GF-210W 2 Gallon Humidifier
Leaking rubber boot
Mine did the same thing at the end of last winter. I did not discover it to be one of the rubber tubes (boots as you say) until I went to use it this past fall. The manuf. said send it back for a replacement (they do not fix these or offer parts) which I did in Nov. and still have not received the replacement. Nice deal for them.
Feb 05, 2008 | Slant Fin Warm Mist GF-350 Humidifier
Installation of mineral pads
The nozzle is NOT fixed in place. Force it either clockwise or counterclockwise (it doesn't matter. Then simply lift up. Deposits may have accumulated leaving the impression that it cant be moved, but it can!
Jan 26, 2008 | Slant Fin Cool Mist GF-220 Humidifier
Clean/refill light
My Slant Fin humidifier has a floating, ring-shaped magnetic level that isn't replaceable. You can't even tell it's magnetic until you cut off the piece that prevents the white plastic float from rising past a certain point. It turns out that there is a ring-shaped magnet in the float.
I found that the Refill light would go off when I held a strong magnet near the float device.
So, I have suspended the magnet with string from the top of the humidifier outside the humidifier.
Caution: This fix disables the safety feature inherent in the low level shut off. I wonder why the manufacturer uses material that corrodes?
Oct 14, 2007 | Slant Fin Warm Mist GF-350 Humidifier
ER3 Message
We had this problem and could not make it go away by refilling, jiggling the float and so on. All the controls appeared frozen during this time.
But unplugging the humidifier for 5 minutes and plugging it back in seems to have fixed it -- no ER3 message now (fingers crossed!0.
Apr 25, 2007 | Slant Fin Warm Mist GF-210 Humidifier
Slant Fin Cool Mist GF-220 Humidifier Logo
688 people viewed this question
Top Slant Fin Humidifiers Experts
Marvin
Marvin
James Gettemy
Tom Chichester
Are you a Slant Fin Humidifier Expert? Answer questions, earn points and help others
