Question about Cameras
My Canon 5D sometimes has an underexposed area on the lower left corner of the image. The are is in the shape of a long triangle and it looks like something is obstructing the lens. It does this with any tipe of lens I use on it and I check it but I do not seem to find the reason for this. Can you help? Many thanks. carmen Morosan
  • 1 more comment
  • photographiq Dec 07, 2008
    Can you help?
    Unfortunately is not the battery or the lens. The camera is relatively new and it has the same simptoms with a series of lenses and working on a power grip.
  • photographiq Dec 08, 2008
    I think a service center is the solution. Nothing helped and I can bet is a CMOS issue... Thanks for all the suggestions.
    Sergeant:
  • 399 Answers
Try to tap on the sides of the camera if something is obstructing the lens it gets away and will work properly. as u said its not the lens or the batteries because they r new may be the camera has internal circuit failure.as if it is under warranty is is advisable to replace the device.
Posted on Dec 07, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, I would venture that the CCD, the image capturing device has a speck of dust. Of course cleaning would resolve the issue. Should this be not the case, the it is probable that the CCD has a temperature imbalance and could only be rectified with replacement.
Good luck and Thank you for using FixYa.
  • Cameras Master
  • 6,487 Answers
Try first to reset the camera using the reset option on its Menu , just to make sure it not a problem with its settings....
    Genius:
  • 1,550 Answers
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work
Hope this helps .
If your problem still continues you need to take to service center .
Posted on Dec 06, 2008
Water damage 5d
Your camera is probably a lost cause, but if you remove the covers you may be able to clean the corrosion off of the circuit boards. Put a small amount of WD40 on a Q-tip (don't squirt it on the board). It does a good job of dissolving corrosion. If there is corrosion in the flex connectors the flexes plug in to the board they are on will have to be replaced. Some boards require software to replace.You do have a chance because this camera doesn't have built in flash, so you did not short 300 volts into the circuit.
If it was sea water it drastically lowers the odds of success.
Oct 08, 2012 | Canon EOS-5D Digital Camera
Image on viewfinder is very distorted and saturated. Image seems to be fine when I download them. I checked all settings and replaced CF card with no luck. Is this the sensor?
If the pics are fine when you download them, then the sensor is fine. The distortion is more likely a screen problem. Sometimes a small crack in a corner will cause such a problem.
Oct 13, 2011 | Canon EOS-5D Digital Camera
GE 46GW947 TV. Screen is yellowed on top right corner with triangle shape a little less than full screen. Cleaned lenses and picture got clearer but still yellow on top right.
If you are able with the set on look into the three lens, what you are looking for is is there an visable liquid in any of the three lens on top?
These sets use a sealed area with Glycol, sometimes it leaks out so it is on top of the inside lens, DO NOT TRY TO REMOVE LENS COVER IF YOU SEE THIS.
SD TECH
Apr 13, 2011 | GE 46GW945 46" Rear Projection Television
How do I get the language back to English on my Canon Power Shot sd3500. I mistakingly chose a language that I have no knowledge I can't understand the instructions on the camera. I followed the...
Press the Play button (the right-pointing triangle). Touch and hold MENU in the lower right corner of the screen. (If there are images on the memory card, touch FUNC at the lower left corner to display MENU.) Touch English, then touch the curved arrow at the upper right corner.
Doesn't this do it?
Jan 07, 2011 | Canon PowerShot SD3500 IS / IXUS 210...
My Canon EOS-5D 12.8 Megapixel SLR Digital Camera gives me many shots during a shoot with areas in the picture of different colors, like stripes running thru the whole image, usually one color. They run...
Image transfer chip from lens may damager or not getting proper connection from lens. Thats why does not fixed on a perliculer location. Please visit canon service center.Just close your eyes and think how a image comes via lens & showing in display. You will get the ans. watch the photo.759a276.jpg Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Canon EOS-5D 12.8 Megapixel SLR Digital...
Sony kv-36hs500
This sounds like the beginning of a convergence IC failure. If you can solder, you should be able to resolve this yourself. Let me know if that is what you wich to do and I'll provide some additional details and instructions.
Dan
Aug 01, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Powershot continued
(In the future, please respond on your the same page as your original question).
Look in the lower left corner of your LCD. You should see a letter (L, M1, M2, or S) and a shape to the left of it. If not, press the Display button until you do. Then follow the instructions on the previous response.
May 09, 2008 | Canon PowerShot S1 IS Digital Camera
Canon 5D resolution question
The 5D has a 12.8 mega pixel sensor.
2 x 4 ft. is 24 x 48 inches, so you have to cover 1152 sq. inches using 12.5 million pixels.
Spreading 12.5 million pixels over 1152 sq. inches means 10,850 pixels per sq. inch. Taking the square root gives you a maximium resolution of 104 pixels per inch (or 'dpi')
Photoshop will allow you to increase the resolution by a process known as 'interpolation' .. increasing to 300 dpi using Photoshop before printing will give a better result.
NB. Depending on your printing process, you may end up dealing with files up to 500Mb in size ....
Mar 12, 2008 | Canon EOS-5D Digital Camera
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
