Question about Miele 24 in. Incognito G843SCVi Built-In Dishwasher
F 13 problem indicated on miele g2420 optima dishwasher
Keeps shutting off manual says water intake problem. Water is going in fine, pressure is good but I don't have a user maintenance instructions booklet. could anyone tell me how to find the water intake filter so I can see if it needs cleaning.
  • Anonymous May 24, 2009
    F13 Flashes on screen and program indicator entirely lit up. Optima series G2420 or G2430
  • 122 Answers
Its on the end of the water intake line - ussually under the sink - connected to the hot water line.
Posted on Jan 04, 2009
Intake/drain light on
Please check the INLET water pressure, remove the inlet and check. Now if there is pressure make sure that when the power is pressed there is a pre wash cycle to start the machine. If not there is fault in the program controller , please check the door switch and the panel board.
Jan 02, 2013 | Miele Optima G2470SCVi Built-in Dishwasher
Optima G2430 Miele dishwasher with F13 error
F13 Indicates that you have a water intake fault. The machine is not receiving the the proper amount of water quantity. You could turn off the water supply and disconnect the water inlet hose. There is a filter inside, to remove the filter you have to take out the seal and then you could use a pair of needle nose pliers to take out the filter basket. If the filter is clean you and your water supply is good, you have a problem with your flow meter not registering pulses when the water is taken in.
Feb 05, 2012 | Miele 24 in. Incognito G843SCVi Built-In...
My Miele G2430 dishwasher stops right after draining in the first minute or so after starting, and the intake and drain light comes on. The solenoid at the end of the intake hose then clicks and the light...
Hi
Intake/Drain light flashing means an issue while draining. The dishwasher is not draining properly. Please check for air gap on the dishwasher is not clogged. It prevents dishwasher from draining properly and sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Keep handy large bowls and towels to soak the water out. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections and switch it on. If the error still appears then turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs to cancel the error message. Switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Feb 23, 2011 | Miele Optima G2430SCi Stainless Steel...
What is error code 3 on the Miele dischwasher?
I dont think that the error code is 3 it must be 13.
If it is 13 then, this error is a flow meter error. You will need to pull the dishwasher out and it on the side there is no way to reset it it will need to be replaced fairly common issue.
Remedy is to open the stop clock fully - clean the water inlet filter - th e water pressure at intake is lower than 30kPa (0.3 bar)
Aug 29, 2010 | Miele 24 in. Touchtronic G694SC Built-In...
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
I had a similar problem with a different Miele. I found that under the door, there is a removable trim panel (may not be one on yours). Under the trim panel was an acoustically sealed metal plate held by a couple of screws. i switched off and disconnected the electrity, then removed the plate. The bottom tray was filled with a big puddle. I cleaned that up and put the machine back together and it ran fine. Accordingly, I'm getting some replacement shaft seals for the thing as it looks like its worth fixing. Good luck with yours. rupertvdP
May 31, 2009 | Miele 23 in. Novotronic G841 Built-In...
I have a brand new Miele dishwasher which has worked grate since it was installed 2 weeks ago. It keeps shutting itself off & indicates an F13 fault. I looked in the manual, see that water is going in...
On my Miele 1220 dishwasher, the inlet filter is inside the inlet hose connector, where it screws onto the water supply. To clean it:
1. Turn off the stopcock. 2. Unscrew the inlet hose. 3. Remove the black rubber seal gently with a screwdriver. 4. Use pliers to remove the inlet filter. 5. Clean the filter under running water. 6. Replace the filter and seal. 7. Reconnect the inlet hose to the water supply, making sure the screw does not thread. 8. Turn on the stopcock slowly to check for any leaks.
Dec 06, 2008 | Dishwashers
Miele Dishwasher G2170 scvi type hg03 dishwasher problem
Remove and check the "non-return valve" and make sure it's clean. It snaps out and in easily. See page 47 of the manual for this dishwasher.
May 20, 2008 | Miele Advanta G2170SCSF Dishwasher
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Dishwasher not running
just got this, and have same prob, i have run through all checks
Aug 26, 2006 | Miele Premier-Plus Built-in Dishwasher
Miele 24 in. Incognito G843SCVi Built-In Dishwasher Logo
1,165 people viewed this question
Top Miele Dishwashers Experts
icatci
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
