Question about Samsung HLR5067WX 50" Rear Projection HDTV
Vibrating noise inside hlp5063wx/xaa
I pulled bulb out and blew out dirt checked little fan off to left of bulb then fan that is off to right back behind bulb seems more like vibration from pkastic touching something does not do it all the time sometimes loud sometimes not if i tap back t will stop for awhile what could it be
    Genius:
  • 1,239 Answers
Hi
noise you are hearing can be the fans inside with bad bearings and or what im assuming given the info you gave.More likely the motor inside the optics engine (color wheel) is making noise..This will also cause picture problems..very expensive to repair..
Posted on Dec 06, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 06, 2008
    Sounds like the color wheel or coolin fan both can cause this symptom. If it stops as soon as the set is turned off its probably the color wheel. If it continues for a minute after power is off its most likely the cooling fan.
  • 340 Answers
Hi and welcome to FixYa,
Replace your little fan, that’s from where your noise come.
regards
Teis
    Genius:
  • 1,550 Answers
The color wheel need replacing.
Color wheel runs at high RPM it creates that vibrating noise .
It is not worth to fix it .
How old is your tv ?
Left headlight replaced but still not working, swapped with right bulb so bulb is good
If you checked for power inside the socket(power and ground) the bend the tabs in the socket to touch the bulb wires. They get hot and bend. pull them out a bit.
May 19, 2015 | 2008 Hummer H3 Alpha
Optoma movie time projector has a vibrating sound
Normally this sound noise is the small FAN inside. Dirty or faulty. You must open the proyector, or go to some shop repair.
God bless you
Jan 25, 2013 | Optoma EP706 Projector Remote Control
I have Hunter ceiling fan / light. I installed it. It worked fine for a little while, than one bulb blew out, then a second bulb blew out, now none work. Yes I repaced all the bulbs, still don't w
I would check with a voltmeter if you can safely to verify power at the light socket using an adapter to a plug in it. If you can not do that, with power off you may want to make sure that the socket contacts are good and clean. Sometimes they can become tarnished badly.
Oct 10, 2012 | Hunter 23852 Classic Original Ceiling Fan
I have a HLP5063wx/xaa and when I turn if off I hear something like a fan winding down. Also every once in awhile when I turn it on the people are red but i turn it off and back on and everything is
Yes the fan can be replaced but I believe your issue is actually the colorwheel which is going bad which can lead to color issues eventually the set will refuse to power up if the bearings fail completely inside the colorwheel
Jun 15, 2012 | Samsung Televison & Video
Noise vibration
if you take the back panel of the freezer out you can get to the condenser fan they do have a habit of going bad and actually having the fan and shaft move forward on them usually when you start hearing the noise it is not long before it goes out completely.
May 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Vibration
It sounds like a possible bad front wheel bearing they will make like a humming or growling noise.The pull could be air pressure a little lower in the right front tire than the left front check the air in all tires and if pull is still there take the left front put it on the right front and put the right front tire on the left front.Sometimes tires get what they call radial pull and that will fix it or make it go the other way if it goes the other way either get new tires or put the back tires on the front of the vehicle and put the front tires on the back.
Feb 22, 2009 | 1992 BMW 7 Series
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Loud humming noise
Usually a humming noise is a transformer going bad.
Jan 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung HLP5063WX/XAA 50" DLP
Here is a site for ColorWheel replacement, which is what you need to do if you hear that screeching or fan running noise coming from your TV. Sometimes the wheel just explodes which gives you no picture.
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Sep 29, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
87 people viewed this question
Henry  Thomas
Henry Thomas
