Question about Ruud UBHC Air Conditioner
My ruud unit will kick on and work for heat pump but when it tries to kick on for emergency heat it will not ignite. sometimes the ignitor will glow sometimes it wont
  • 85 Answers
In order to diagnose your problem, you will need to set your therm on emergency heat only, watch the cycle in your furnace, and tell me what it does once it tries, and how many times it try's and what it does once it's tried and stopped?
Posted on Dec 06, 2008
I have a 20 year old Ruud gas water heater with a power vent. The model is PVP 40-1. Sometimes it will not heat water. The power vent is running but neither the ignitor or the burner is. If I turn off the...
My guess is the ignitor needs replacing (old and has built up too much internal resistance). Even though it still works at times, I would suspect it first, even if it glows during an ignition cycle.
Dec 07, 2014 | Water Water Heaters
Gas oven turns on sometimes but not others. when turned on the heating light and oven on lights turn on but the gas does not kick on.
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 20, 2010 | Ovens
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
MY ruud silhouette gas furnice unit comes on but burners don"t.can't see pilot light.the unit has electic ignitor
You either have a spark ingitor or you have a glow coil ignitor. The glow coil ignitor is located on the left hand side of the burners. It is a very fragile part.
If you have a mirror or have good eyes, look to see if
it has a crack in it.
Feb 19, 2010 | Ruud UBHC Air Conditioner
I have the same Ruud Achiever unit & it's not working.
It sounds like it will need a hot surface igniter. This is the part that glows when furnace is turned on, and tells gas valve to release gas for it to ignite. At that point funace is lit, it heats up flame sensor witch inturn tells fan to start.
Sep 30, 2009 | Ruud UBHC Air Conditioner
Ruud heat pump question
Does the air handler take a minute or two to start, this would be normal so that it doesn't blow cool air into the house before the unit is warmed up. If not could be the fan relay is weak and needs replacing. As far as the outside unit it sounds like you need to check the refrigerant. In cooling they are 70/150 psi. This should be checked in cooling mode, once you turn it to heating mode the pressures switch bring heat inside the house instead of out. I hope this helps.
Oct 23, 2008 | Ruud Heating & Cooling
Ruud UBHC Air Conditioner Logo
56 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
