IAM USING DELL XPS 1330 WITH 4 GB RAM.. BUT THE LAPTOP'S PERFORMANCE IS REALLY VERY SLOW.. THIS IS JUST LIKE MY DESKTOP WHICH HAS GOT 1GB RAM AND THE SPEED AND PERFORMANCE IS MORE OR LESS ONE AND THE SAME... CAN ANYONE HELP ME WITH THE PROBLEM...AS THE BOOTING TAKES ATLEAST 3MINUTES AND MOREOVER THE SCROLLING IN THE TOUCH PAD STOPPED WORKING
  • 3,940 Answers
1. Uninstall Unneeded Programs (Start, Settings, Control Panel, Add/Remove Programs) Keeps at least 10% of your HDD free, 20% is preferred. Windows uses this space for it's swapfile.
2. Scan Your Hard Disk for Errors. (Double-Click MY COMPUTER, Right Click C:, Properties, TOOLS TAB)
3. Scan for Viruses (If you don't have an updated and functional AV, http://free.grisoft.com)
4. Check for Spyware and Adware (http://www.download.com, Spybot search and destroy)
5. Defragment Your Hard Drive (Double-Click MY COMPUTER, Right Click C:, Properties, TOOLS TAB)
6. Adjust Visual Effects for Better Performance (Right-Click the MY Computer Icon, Properties, Advanced TAB)
7. Stop Programs from starting on Windows boot (Start, RUN, MSCONFIG)
If you touchpad isn't scrolling, then the touchpad driver either isn't installed or the MSCONFIG startup line has been disabled.
Posted on Dec 06, 2008
    Genius:
  • 1,061 Answers
I HAVE RECENTLY BEEN USING A GREAT SOFTWARE PROGRAM ITS CALLED REIMAGE...GO TO THERE WEBSITE AND DOWNLOAD THE SCANNER.LET IT RUN THEN GET THE SOLUTION.IT DOES HAVE A SMALL COST.BUT IT HAS ENABLED ME TO FIX/REPAIR MANY LAPTOPS AND DESKTOPS THAT AT FIRST THOUGHT MAY NEED REPLACING.ITS EASY QUICK AND SAFE.http://www.reimage.com/home/?tracking=google&banner=errors&gclid=CKPTnbyorJcCFRg6awodODceiw.RICHARDM69
I put the memory stick in my dell but the computer does not upload the device. so I went to control panel in devices and printers and I can see the devices but when i say add to this computer it's
Memory sticks are not devices such as printers and
Dell XPS 400 PC Desktop
Installing RAM on a desktop computer is of moderate difficulty for most non-technical people. Before beginning any memory upgrade, make sure the proper RAM has been purchased. The Dell XPS 400 requires DDR2 RAM (240-pin DIMM).
Preparing the Computer b> The computer must be unplugged before any work can be completed and the proper precautions must be taken, such as wearing an anti-static wristband. Also, replacing the RAM on a Dell machine could void its warranty. To install the new RAM, the case of the computer needs to be opened. Replacing the RAM b> The motherboard has four RAM slots. Each slot takes one stick of RAM (up to 1 GB per stick). The XPS 400 can utilize up to 4 GB of RAM. If adding RAM, put the new RAM in an empty slot. If replacing the RAM, take out the existing one and then put the new RAM into the machine. Important Notes b> While the Dell XPS 400 has four RAM slots, if only two sticks of RAM are to be used, they must be inserted into slots 1 and 3 or slots 2 and 4 for optimal performance. A single stick of RAM should be inserted into slot 1. Always put the largest ram module closest the CPU central processing unit.
Start your computer Wait for Windows to load. Click on "My Computer" and select "Properties" using right-click in the Explorer window. This will open "Systems Properties." Click on the "General" tab. Here you can view the physical memory installed on your computer. The amount indicated is the total RAM installed on your computer. RAM is usually 32 MB, 64 MB or 128 MB in older PC versions. Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
b>If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system. You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Mar 01, 2013 | Dell XPS 400 PC Desktop
Overheating
install more ram not having enough ram your games will run slow
games use a lot of graphics especially if they are animated
if you need more help on the installion of correct ram post a reply with your motherboards specifcs
hope this helps
Feb 14, 2012 | Dell Studio Xps 9100 Desktop Computer
Where can i find the motherboard on a del xps 1330
Consult the Dell branch for a new motherboard, but it will set you back with the same price of a new laptop. The Bios battery is the round shaped battery with the holder or simply by the connecting wire such as this12_14_2011_8_19_08_pm.jpg
Dec 14, 2011 | Dell XPS M1330 1330
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
I am using a laptop aspire 3683 wih 512mb ram. But my computer running very slow. Can I upgrade the ram for 1gb. Please let me your suggestion. Thank you.
Yes, you can upgrade it to 1 GB RAM.But I recomend you to change it to 2 GB RAM (two 1 GB RAM).It will boost your performance tremendously.
Consider1 GB RAM with 600/666 Mhz.
Dec 31, 2009 | Acer Computers & Internet
Slow file transfer
try scanning ur system for viruses if u have nt done it yet..sometimes wen u have viruses on the system or on the pendrive the file transfer rate gets slow.
Jun 03, 2009 | Dell Studio XPS 16 Notebook
I upgraded the memory from 1Gb to 2 Gb but my laptop's still slow
it can't be, check if the windows is reading 2gb from system under control panel.
to find out if your pc is fast, see if it plays a game faster than before or use a program faster than before
there is no diffrence in using windows itself. example i think in your mind you'd expect to click on my documents and it loads it super fast now with 2gb of ram? no, you're wrong weather you have 1gig or 2gig windows still works the same
the diffrence is Faster file transfer, faster applictions but not a faster windows.
it could also be the norton if you installed, it lowers your speed.
check Task manager, in the performance section
cpu usage should be under 10%
and pf under 500mb
Mar 03, 2009 | Toshiba Satellite M55-S3512 Notebook
Me again with the dell 1330
Yeah, I figured this would help ya. There's no way around the internal card, but keep in mind that the 256 is up to 256, it only uses what it needs up to 256, and really shouldn't ever get to the 256 level, unless you're gaming with some extreme graphics and hooked to multiple monitors. You're topped out at 4g, but 4g is huge and again, you'll never use it all unless your gaming with it, and it doesn't sound like you're gaming with it. An example of a serious gamer is one of my customers that my partner and I set up a system that consists of 1 Alienware gaming tower as a server, with a 1 terabyte hard drive with 8g ram, 1 Alienware gaming laptop, with 2 300g hard drives and 6g ram, and 2 Dell XPS laptops, both with 250g hard drives and 4g ram. All connected to 5, 24 inch flat panel monitors and surround sound for the full panoramic experience. This is gaming at the extreme. Me personally, I'm content with solitaire. Glad you're happy with the performance, sorry you wasted the $120, sell it on Ebay, somebody will buy it, and if you need anything else feel free to ask.
Jul 25, 2008 | Dell Inspiron XPS M1710 Notebook
Computer best to buy
go for a DELL XPS 1330 laptop
or get any DELL XPS desktop
you can get details on www.dell.com
and if you are in UNITED STATES
call 1-800-999-3355(DELL SALES)
Jun 06, 2008 | Dell Dimension 4600 PC Desktop
XPS 1330 cracked screen
MONITOR DEPOT, INC 5359 WEST RICHEY ROAD
HOUSTON, TX 77066
Mar 09, 2008 | Computers & Internet
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
